Bleeding
Old May 31, 2001 | 01:53 PM
sigmanu1524's Avatar
Post Bleeding
I did my fronts and I found it very easy- everything is pretty self explanitory. The only problem I had was getting the screw loosen to bleed the calipers. I did push in the pistons on one withour bleeding, for furutre reference how should I di that if it is a little stripped.
thanks
Old May 31, 2001 | 03:06 PM
fordtec2001's Avatar
Post
visegrips then replace the screw with a new one
Old Jun 1, 2001 | 01:02 AM
Barto24's Avatar
Post
Try something like PB blaster(works best) or WD 40 on the screw before trying to loosen it. Soak it with whatever you use and let it sit for a few mins then try.
PB Blaster worked great for me
Brian
98 F150 XLT Supercab 4X4
4.6L V8 3.55LS
Tonno Cover, Brush Guard, Dukes of Hazzard Dixie Horn, 2 150 watt KC Daylighters, Cobra CB Radio, BF Goodrich All Terrains 265/75/16
http://hometown.aol.com/barto24/brianstruck.html
2000 Excursion Limited 4X4, Black, V-10, 3.73 LS, Tow Mirrors
