Using ALOT of brake fluid.
98 XLT 4x4, I keep having to add brake fluid roughly every 3 weeks, 70% hwy/30% town driving. Because of this I've been taken extra care not to do any hard braking but it doesn't seem to help. Any suggestions or is this normal? Thanks in advance.
This is absolutely NOT normal. You must have a leak somewhere. First place to check are the 4 wheels. Then check all the brake tubing all the way from the wheels to the master cylinder. If they're dry, then you probably got a bad master cylinder. To check that, pull off the vacuum hose from the power booster and stick a screwdriver into the hose. If the master cylinder is leaking, the brake fluid will be drawn thru the booster and into the hose. You should find evidence of brake fluid in the hose.
BTW, I'm assuming the obvious that the fluid isn't leaking out of the master cylinder reservoir or cap, yes?
You have a leak. Bottom line______________
97 F150 Longbed V8 4.6
K&N air filter
K&N FIPK tech MOD & removed elbow silencer
Tires: Yokohama 265/75/16 Geolander AT+
Hyper white xenon bulbs
Bedliner and raven shell
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
K&N air filter
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
oh man.........brake fluid theif.
I had to read that one a couple of times to make sure I read it correctly.
For me, I'm almost certain that I've got a nasty gas gremlin
sorry....couldn't resist.....
Black 98 F150-XL, 2WD 4.6L 5spd., RegCab,
Short WB, Windsor Triton (slapless to date),
3.08 rear, Air, Rear Slider, Triton V8 Badges,
Duraliner Boxliner, K&N, Ziebart, Castrol Syntec,
HAWK Plus Bedcap, profile+ wrap-around bug deflector,
Blazer Neon-Blue Projector fog lights, custom look'n door cracks
Tinting: #4 RearCab & Bedcap Windows, #2 Cabside Windows
My Site
My Site
