Slight Squeel ...........
I had to stop suddenly last week, because a young teenage punk pulled out in front of me. Ever since then I've notice a slight squeel; it appears to be coming from the front, under moderate brake pressure. Not light and not hard but in the middle and while the brakes are warm.
I was told to take off the pads and sand the reflectiveness off. I did, and it's still kinda of squeeking some what.
Should I take it back to the dealer and let them fix it?
Thanks In Advance ...
• 2000 F-150 XLT
• 5.4 LITER TRITON V8
• 4X4 OFF ROAD PACKAGE
• SHORT BED EXTENDED CAB
• BRIGHT RED CLEARCOAT
• GRAY INTERIOR
• AUTOMATIC W / MANUAL 4X4 SHIFTER
• 3" PERFORMANCE ACCESSORIES BODY LIFT
• 33X12.50X16.50 BFGOODRICH ALL-TERRIAN KO'S
• AMERICAN RACING BAJA'S 16.50X9.75 RIMS
• FORD SOFT TONNEAU COVER
• BLACK POWDER COATED STERLING EQUIPMENT NERF BARS
[This message has been edited by Nitrox (edited 08-15-2000).]
• 2000 F-150 XLT
• GRAY INTERIOR
I've had to stomp on the breaks maybe twice,
due to some of our finer drivers here in NJ.
Was quick enough to have the ABS kick in.
Anyway, I used to notice a slight little
squeak too develop after a while. I took
my truck to a local Meineke that I've been
going to for a number of years. There
were a few things that needed replacing,
I believe it was the front cylinders, and
they resurfaced the drums/disks too.
I think Meineke has a lifetime warranty on
their breaks too, and they're much cheaper
than a dealer, I'd ask around and find a
good shop.
97F150 XLT SC 4x4 Flairside 4.6 V8 5sp Dk Toreador Red, 3.55LS
ARE tonneau cover, p255/70rx16 tires (came w/235), Superchip
Pioneer CD w/4 Polk Speakers, skid plates
bed liner, side window deflectors, reese hitch, K&N air filter
40s-2chamber Flowmaster, Bosch +4 spark plugs, rustproofing
Better Built Stainless nerf bars
heavy duty shocks
good shop.
heavy duty shocks
My 2 cents. It is under warranty, let the dealer fix it. Also it provides a record that you had a problem in case something more severe shows up in the future.
2000 F-150, XLT, SPORT 4X4, BRIGHT RED/DARK GRAPHITE, SUPER CAB,
SHORT BED, 5.4L, AUTO, 3:55LS, TOW PACKAGE, HD COOLING/ELECT, SKID PLATES
SPORT CLOTH SIX WAY POWER CAPTAIN'S CHAIRS, CONSOLE, SINGLE CD,
CRUISE,ESOF,REMOTE KEYLESS, FORD SNAPLESS TONNEAU COVER, FORD BEDLINER,
FORD MOLDED SPLASH GUARDS, FORD BODY COLOR CABSTEPS,
MODS: CATCH ALL FRONT MATS, LUND DEFLECTOR, FORD VENT SHADES,
GIBSON SWEPTSIDE CATBACK,
K&N GENII FIPK,
FORD HITCH COVER
NEXT: SUPERCHIP!!
K&N GENII FIPK,
FORD HITCH COVER
NEXT: SUPERCHIP!!
Nitrox:
Another possible solution to your problem may be to "seat" the brake pads.
I had a squealing brake problem which was only getting worse until I used this technique. Subsequently, the squealing went away and there was a noticeable increase in braking effectiveness. One down side, there was a lot more brake dust.
I have since traveled over 5000 miles with not a hint of the brake squeal.
If you wish, try a search under Seating Brake Pads. You'll find the details on this technique which, by the way, are quite simple.
Good Luck, Wilk.
'97 F-150 4x4 Super Cab; XLT 139" Wheelbase Flairside; Silver Frost Clearcoat; 4.6L. (Romeo); 4-spd Automatic Transmission; Preferred Equipment Package 507A; 3.55 Limited Slip Axle; Electronic Shift 4x4; California Emissions; Sliding Rear Window; Trailer Towing Package; Off-Road Package; 6-Way Power Driver's Seat; Remote Keyless Entry/Anti Theft; 6-Disc CD Changer; Ford Bedliner; Ford Running Boards; Ford Nose Mask; Roll n Lock Tonneau Cover.
2000 SVT F-150 LIGHTNING XLT; 120" Wheelbase; Flareside; 5.4L EFI SOHC V8 SC Engine; 4-SPD Automatic; Silver Clearcoat Metallic; Roll n Lock Tonneau Cover; SVT Online Store Lightning Front End Mask (still in box).
Good Luck, Wilk.
