Code 0174
Old Dec 6, 2002 | 07:14 PM
jwill1's Avatar
Talking Code 0174
I finally fixed it. It was so simple I'm embarrassed to tell you what it was. A vacuum line had a hole in the underside. The hole finally got big enough to hear the leak over the normal engine noise.
Smoke
Old Dec 6, 2002 | 08:17 PM
Navi Man's Avatar
Betcha I can guess where it was at. The line that goes from the PCV valve to the back of the engine. The elbow wears out and a hole develops. Happened to me just a few months ago. I finally found it the day before it was going into the shop. For anybody out there that has 70,000+ miles on your truck, you might as well replace it now, because it's going to be happening sometime soon if it hasn't already.
Old Dec 6, 2002 | 10:22 PM
jwill1's Avatar
You are correct. It only cost me $5 and one knuckle to fix it.
Smoke
97 XLT, Flair Side, Trans-Go Shift Kit, Strait Pipes.
