Fix For Bad Heads?
Hi,
The answer is no.
I've heard you could take the stock aluminum cylinder heads to a competent machine shop and they can add aluminum to the bore to increase thread depth: something i wish I knew about when the shop took off the head before putting a helicoil on (which makes me nervous, since they're not a permanent fix).
Also, I've heard that aftermarket replacement performance heads MAY be available, but I don't know any specifics, or if it's true.
Chris
The answer is no.
Chris
