cold start problem 4.6
Old Dec 4, 2002 | 10:04 PM
svt2205's Avatar
I need some advise. My 98 F150 4x4 4.6 is having trouble starting when it's cold. Recently when it's been below freezing and the truck has sat overnight. I find that when I go to start it, it will barely run for the first 15 to 30 seconds. Motor is only reving at maybe 300 rpm or so. Then all of a sudden, something must be opening up or starting to work, because the motor revs up to about 2000 rpm and returns to a normal cold engine high idle.
My truck has just shy of 110K on it. Fuel filter was changed about 6 weeks ago. Plugs this past summer.
Any ideas? There are times I wish these dam things still ran simple carburators.
Old Dec 5, 2002 | 10:36 PM
wmcnally's Avatar
svt,
Only a guess on my part but I'd check the IAC (idle air control) and the TPS(throttle position sensor).
Good Luck,
Bill
Old Dec 5, 2002 | 11:56 PM
wmcnally's Avatar
svt,
Just found this TSB regarding '98 4.6/5.4 engines: causes rough idle/misfire after cold startup
Make: FORD TRUCK Year: 1998
Service Bulletin Number: 00261 Bulletin Sequence Number: 168 Date of Bulletin: 12/00
NHTSA Item Number: 616826
Component: FUEL:FUEL INJECTION:IDLE SPEED CONTROL UNIT
Bill
Old Dec 6, 2002 | 07:32 AM
svt2205's Avatar
thanks guys for the info. I'll check these things out.
