Buzzing Noise Behind Dash
Old Nov 19, 2002 | 05:21 PM
meanass_f150's Avatar
since it's been cold outside, my 2002 f150 has had this loud intermittent buzzing noise coming from behind the whole dash especially on the passenger side.
it only happens 1-when it's cold outside 2-when i'm stopped completely 3-i'm rolling slowly (brake nor the gas pressed)
i've taken it to the dealer and those jacka$$es gave me a run around that they couldn't hear it. funny how they heard it when i came up there and drove it for them. they ended up installing some insulation in the dash and not fixing a thing. it's getting worse now that it's getting colder outside. it's doing it a lot more.
i've heard 2 theories, 1-the PCV valve or 2-the cable that's found behind the break pedal that connects to the transmission and ends at the stearing column. it's used for gear selection.
does anyone have a clue? i'm getting desperate!! thanks to anyone that can help.
Old Nov 19, 2002 | 07:55 PM
Silver&Blue's Avatar
My truck does the same thing, I know on my truck it is the flasher. Do you have the turn signals on when this happens? Watch you turn signal when this happens and see if it stops flashing.
Old Nov 20, 2002 | 09:00 AM
KT's Avatar
KT
Try the PCV it's cheap and only takes a minute
to put in. It took care of my buzzing noise.
