Oil Vicscosity Consensus
Mobil 1 15-50 w/ Purolator Pure One filter in both my 2000 F150 5.4 and my 89 Thunderbird rainy day and winter ride. I know I am giving up mileage, but I think I make it up in reduced wear and increased bearing life. Every time we have a bearing problem at work, we put 20-50 in it until the problem is solved. The we go back to 5-20 water weight oil.
0W-20 should work just fine. it's the "20" part that is most important. you really shouldn't need the 0W unless you live in a real cold climate; say occasionally -10 degrees or less. when is mobil 1 supposed to come out with this weight? i will definitely use it in the winter here in minnesota.
