difficulty starting
Old Sep 25, 2002 | 07:13 PM
fiskr's Avatar
difficulty starting
For the first time since I bought my '97 F-150 (used--May 2001) it did not want to start. It has been cranking over for a second or two before firing up lately, and I have been contemplating fuel injector servicing and O2 sensor replacement (104,000mi today).
When the truck didn't want to start, the truck was cold and the weather damp (thanks Isadora). Does anyone have any ideas? Check Engine light has not come on. When the truck finally started, it ran as strong as it ever did. Once warmed up, it started with only the slightest bump of the ignition. I'm stumped.
Old Sep 25, 2002 | 07:17 PM
TexfordD's Avatar
I.C.V....
idle control valve...did it not want to idle when it started?die unless you kept the idle up with the peddle?...ICV
Old Sep 27, 2002 | 07:41 AM
fiskr's Avatar
It idled fine. Very smooth. On some occaissions, while sitting at a stop light, it will begin to shudder and the revs will drop slightly. A couple of blips on the throttle usually smooths out the idle. Thanks for your input. I will take a look at the ICV.
rf
Old Sep 27, 2002 | 07:56 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Lightbulb
Some guys were having the same trouble from the PCV elbow on the back of the intake also. The rough idle thing definitely sounds like an IAC symptom, though. Good luck, and let us know what came out of this.,,,,98
