Anyone add oil pres gauge
Hey all,
I guess this is the right forum for this ???
Any problems removing and replacing the sending unit to add a real oil pressure gauge? Can you use a tee to have both? I haven't even looked for the sending unit yet, but assume it's easier that the plugs
Pete
Pete
On the 302/351's its on the drivers side in front of the oil filter on a hexagonal shaped metal extension. Just pop the wire off the top and unscrew it. Not sure on the post '97's. Heres my gages.
They're not autometer, but they look good and operate well, good bang for the buck. There should be no reason you cant run a T and do both. I'm going to, but I gotta get a new stock sender first. It was bad and I figured I'd verify with aftermarket gages.
