Fuel pump shut off switch
Well the truck won't start.
Cleaned the engine friday and on the way home I blew a fuse on my Jacobs ignition. Took it out of line and the truck started fine. Sat morning I changed the plugs and wires replaced the Jacobs fuse and put it back in line. At first it would not start but then started and I have been running it since without a problem. It then started and I ran all over the place sat. and sunday.
Today I go out and it won't start. Checked all the fuses. Pulled the Jacobs out of line again and removed the super chip. Still won't start. I have no fire but no fuel will cause the ignition to shut off also.
It is a long shot but I was looking for the fuel pump shut off valve and according to my manual it should be under the dash over where the drivers right leg is. I looked everywhere under there and can find no switch.
Anyone have an idea what is going on with the truck? Also anyone know where the switch is??
WLF,
I just looked in my owner's guide for my 2002 and it says it's "located in the paasenger's foor well, by the kick panel".
The reset procedure is:
Turn ignition off
Push in on reset button
Turn ignition on, pause for a few seconds, turn off.
Just thinking this might be a good place for a secondary security system. Put a remote power switch in the circuit.
Pete
Turn ignition off
Pete
