Low idle
Old Aug 29, 2002 | 04:31 PM
wemjr's Avatar
Question Low idle
Alright guys, here's the deal. My battery went dead about a week ago, I jumped it off drove to work, dead again, jumped it off and drove to the shop and had the battery replaced. Ever since then the truck has had a low idle in drive while stopped at a light. I thought it may be the computer relearning the idle speed and stuff, but it's been about 300 miles now. The truck runs fine, then when you stop at a light the RPMs drop down to about 400, stay there for a couple of seconds then surge to 700 to 750 then settle in around 600. It doesn't do it at every stop either. Any ideas?
Old Aug 29, 2002 | 07:32 PM
Area 52's Avatar
The idle fluctuation sounds like the IAC (Idle Air Control) valve is malfunctioning. It's located between the throttle body and the firewall. Get a preferred customer discount at your Ford parts counter...should be about $60 unless you're still under warranty. You should be idling in Park at 720 rpm and 600 in Drive.
Old Aug 30, 2002 | 04:20 AM
svtoby150's Avatar
had something like that on a 91 5.0 stang. the MAF sensor was bad, see if you can get the puter scanned.
Old Aug 30, 2002 | 09:16 AM
fade2black's Avatar
I second the IAC, or maybe test your TPS (Throttle position sensor) I cleaned my IAC last week as it was coated pretty bad with carbon.
Fade
Old Aug 30, 2002 | 07:53 PM
Dodge4x4's Avatar
I know exactly what happened. The reason he didnt see the oil is because there was little or none in it to begin with. I don't know for sure, but i KNOW on my mothers expy it burns oil or something like no tomorow. Take 3 qts between oil changes, no smoke, no sooty oily tailpipe, its just not there. So i would venture to guess thats what happened here. And at that particular point in time, it was on its last drop. I hope there isnt a spun bearing, those are no fun. I had 4 on my 70 442---guess who's fault that was---somone drove the pi$$ out of it.
Old Aug 31, 2002 | 06:05 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Thumbs up
I had the same thing off and on the last few years, it seems to stop right after I remove the IAC and clean it each time. I just did this "repair" two days ago lately, and it stopped the dropping idle. I also cleaned the TB plate, MAF sensor, K&N filter, IAT sensor, and tightened up the fipk hoses. It seemed to help alot and the truck feels like it has more power/throttle respnse. I cleaned the IAC a little differently this time. I used a small flat blade screwdriver to gently pry the stopper up and cleaned the surface of it with TB cleaner and a Q-tip. I then let it dry out thoroughly, and re-installed it. The "stopper" is kind of wedge shaped, you'll see when you remove it. Good luck!,,,,98
