rattling noise when starting
Old Jun 24, 2001 | 05:09 AM
DUCKHUNTERnLAB's Avatar
Question rattling noise when starting
anyone familar with a rattling noise when first starting up the engine? It goes away after a while. I'm just gonna get it in for service.
Old Jun 24, 2001 | 02:54 PM
dogman's Avatar
Post
Piston slap-do a search and decide if your noise is the same
Silver 2000 Built 5/26/00
#3299 of 4966
Bone Stock
SnugTop Tonneau Cover
Old Jun 29, 2001 | 03:35 AM
JimCaudill's Avatar
Post
There are hundreds of postings regarding this topic. You should become informed and discuss this with your service manager. As I understand it, somewhere between 1 in 500 and 1 in 2000 owners may have excessive cylinder bore clearance resultin in a "knock" that is evident only on cold start-ups and that should disappear as the engine warms up. Remedy is a specially rebuilt engine that an be installed at little or no cost. Ford states (and I believe) that this is not a reliabilty or performance issue and that their tests have indicated these engines will last as long as those without the knock. I have 62,000 on my '99 and almost always allow the engine to warm-up before driving when it is cold outside. To me it's just common sense. I personally have not noticed anything from truck that I would characterize as "unusual" - I expect it to make some sounds if it is cold, and I wouldn't ask it to start working hard without a little warm-up.
[This message has been edited by JimCaudill (edited 06-29-2001).]
Old Jun 29, 2001 | 09:07 AM
Y2K OffRoad's Avatar
Lightbulb
Most likely piston slap. There are a few people here who have over 100k on a slap-happy motor without problems. You can always opt for the replacement engine, also referred to as an FQR but personally I'd just ask the dealer for a 100k ESP instead of replacing the motor.
My New Baby: 2001 F-150 XLT Sport 4x4. 5.4L, S/C, S/S, Bright Red, Dark Graphite Int., 3.55, Class III Tow/Heavy Duty Cooling, 4 wheel disc ABS, Overhead Console, Factory In-Dash CD, Remote Keyless Entry.
Mods: Westin Nerf Bars, Ziebart Rust Protection, Ford Bug Deflector, Ventvisors, Cabin Air Filtration
Future Mods: Superchip, Air Force 1, Spray-in Bedliner, and Retrax.
2000 Polaris Sportsman 500, Camo Green, 4x4, 499cc 4-stroke, independent suspension, shaft drive, 4 wheel disc brakes, etc.
