Removing coil pack wires
Doing my first plug change, I can't get the wire plug to come off the coil pack. Looks like a little plastic tab needs to be pushed down but still can't disconnect it? What's the trick?
Loosen the drivers fuel rail and remove the power steering brace and the job is a breeze. Not difficult at all. Make sure you hold onto the front two injectors when loosening up the fuel rail though. Good luck.
