heat related fuel prob?
<font face="Verdana, Arial" size="2">Originally posted by zrhino:
oops, 91, with the 5.0 liter...</font>
Maybe way off base here, but that's just my understanding of it. Only way to resolve it is to let it cool down or move the fuel lines away from the engine as far as possible.
Good Luck.
1997 F150 4x4 XLT, SuperCab, Short Box, 5.4, Royal Blue/Silver, K&N, Gibson SS, LT265/75/16 Wild Country APT's
I think it's the fuel pump.
I had a 1985 Ford Thunderbird with the 5.0 and a 1985 Olds Calais, and both had the same problem and it turned out to be the fuel pump. Good Luck !!
1997 F150 5.4L Supercab 4x4 "Off Road Package" Tow Package 46000 Miles
All stock except for an Alpine Stereo/CD Player, Soft Cover, Bed Liner, and a Custom Painted Bug Deflector.
went to Phoenix last weekend, 106 stinkin' hot degrees. Truck started to lose power, got off interstate, it died. Would restart, run really rough for 2-8 seconds, die. Repeat dozen times. Switched to rear fuel tank, ran good. Switch to front, die. Switch to front that evening when cool, ran good. Filter? Pump? Thoughts?
I know that in 89 they had a recall for the valves that switch from one tank to the other. That could also cause your symptoms.
2000 Harley/Davidson F-150
#6738, Built Thursday Sept 21, 2000
Superchip!
K&N FIPK Gen II
Lund Bug Deflector
Ventshades
Century "Cargo Cover"
89 F-150 Lariat 4X4 for the "dirty work"!
Superchip!
K&N FIPK Gen II
Lund Bug Deflector
Ventshades
ZRHINO,
I read an article a while back about the same symptom. It turned out that the fuel tank evaporative emission control line and/or gas tank cap was plugged or faulty. One purpose of the evap line permits the tank to breathe (so to speak) and allow air to be pulled into the top area above the fuel level in the tank, while fuel is being pulled out, thereby reducing a vacuum build-up. You state that there's no problem with the other tank. I would rule out a fuel pump problem because the pump is able to suck/push gas from other tank. A vacuum condition could be occuring in the one tank, causing a decreased flow of fuel. An opposite force (vacuum) could get to the point where it counteracts the pump working pressure. While driving, your truck ran crappy off of the one tank...then at a stop, the engine quit. The obstruction could be liquid fuel in the evaporative lines caused by overfilling that one tank when you visited the gas station prior to your Phoenix trip.
It might be worth it to unhook the overflow line to see if there's an accumulation of fuel present. The line should attach to the tank filler neck and then runs along the frame to the engine compartment.
Note: If both tanks share the same line...then this theory is blown out the window.
Hope this helps....I'm curious to know what you find out. Please post once you've resolved it.
Good luck!
2001 F-150 SuperCrew, Lariat 4x2, Black w/gray leather, 5.4L Engine, Towing package (1.02" radiator)
Modifications: Gibson SideSwept Exhaust, K&N filtercharger w/modified cold air box, ******* lid, Bed Extender, Ventvisors, Hood deflector, Black Stull Billet Grille, Lightning Tails
Shopping List: Oil filter relocation, Front & Rear Swaybars, PermaCool Cool Pack II dual electric fans (available this summer)
[This message has been edited by Area 52 (edited 06-20-2001).]
Good luck!
