Best Synthethic Motor Oil?
I use Amsoil 0-30W and love it. Will change at 5000 mi intervals (per Ford warranty issues). I would probably change at 5000 mi intervals anyway even if it can easily go well past that. IMHO, engine oil is just too important, and it is relatively cheap insurance.
GDG
Stock Package: 2001 SuperCrew XLT, Silver, 5.4L, 4x4, 3.55 LS, Tow Package, 265x70x17, Sliding Rear Window,
Modifications: Tuff Spray-on Liner, JBA Headers Jet Black Coated, True Duals with Magnaflow X-pipe 2xRavin Z55's 18"x3" Stainless Tips exiting before the rear wheel, K&N FIPK with fabricated cold-air box and ram-air, SuperChip, ASP Pullies, 1" Thick Sheepskin seat covers (nice "seat-of-the-pants" feel!), Nerf Bars, PIAA Superwhites, 65W (9006) Fog Lights, Dual 14" Perma-Cool Fans w/ stock shroud, Baumann Shift Kit on Stage 4 with Sonnex Bypass Clutch control Valve, B&M Deep Trans Pan, Pillar mounted Autometer Ultra-Lite Water and Tranny Temperature Gages, Amsoil front to back, TPS Mod to 0.999, Custom ported TB.
Future mods - Roots Supercharger, modified sterio system
[This message has been edited by GoDogGo (edited 06-15-2001).]
GDG
What about the interval difference between changes? If I use a synthetic and change the oil out at 7500mi - or whatever is recommended for the specific oil I'm using(filter at 3000mi) do you think that it makes a difference to FORD? I assume that they recognize that synthetic change intervals are longer than regular ones, but that may be an incorrect assumption.
<font face="Verdana, Arial" size="2">Originally posted by LuckyScrew:
What about the interval difference between changes? If I use a synthetic and change the oil out at 7500mi - or whatever is recommended for the specific oil I'm using(filter at 3000mi) do you think that it makes a difference to FORD? I assume that they recognize that synthetic change intervals are longer than regular ones, but that may be an incorrect assumption.</font>
My service manual states that only API certified oils may be used (some synthetics are not API certified), and that when using synthetics normal change intervals must be maintained. So unless you want to risk any possible warranty concerns later, the potential cost savings of using synthetics won't really pan out until after the warranty period has expired.
