Is It True?????
Old Aug 18, 2002 | 11:32 PM
offroadmaniac's Avatar
Exclamation Is It True?????
I heard awhile back from an owner of a local shop that to remove and put in a different engine in later model fords ('97 and up) the cab has to be removed first. Is that TRUE??????
Old Aug 18, 2002 | 11:44 PM
FleasF-150eatshondas's Avatar
Wouldn't suprise me... they're tucked in there...
-Flea
Old Aug 18, 2002 | 11:54 PM
mjhpadi's Avatar
It sure would make changing plugs in the 5.4 easier
Old Aug 18, 2002 | 11:57 PM
wittom's Avatar
There was a controversy here not too long ago about this. You could try and find it with a search.
I guess that it is an option.
Old Aug 19, 2002 | 12:10 AM
f150freak's Avatar
I know thats how they replace an engine at the dealerships. Compltelty remove the cab of the truck and R&R the engine.
Old Aug 19, 2002 | 09:52 PM
hmustang's Avatar
It may be a little easyer to do it that way but I think you can get it out with out removing the cab just remove the grill and all the stuff infront of the engine and pull it out that way.
Old Aug 20, 2002 | 12:11 AM
Tiger's Avatar
There were some guys several months ago that confirmed the dealer removed the cab to pull heads, if they had the equipment to pull the cab. Otherwise, there was an arduous procedure for pulling heads.
