K&N air filter question>
Screwdriver, did you remove the intake silencer and elbow silencer?
-AR
2001 F-150 XLT 4x4 Off-Road, SuperCab, Flareside, Black[*] 4.6L Triton V8 HPI[*] 5 Speed / 3:55 Reg. Axle[*] Keyless[*] Premium Audio CD
Mods:[*] K&N Intake (Chopped Airbox)[*] Removed Elbow Silencer[*] 3" Cat-Back (No Muffler, Turn-Down)[*] Cranked Torsion Bars[*] APC XENON PLASMA Super Whites[*] '01 "L" Taillights[*] Bugshield[*] Bedliner[*] Ventshades[*] Removed Mudflaps[*] "Light Argent" 4x4 Off-Road Decals
Audio:[*] Clarion 6675[*] Rockford Fosgate 5x7's[*] Rockford Fosgate G360A2 Punch Amp[*] JL 12W3-D2 (Ported)[*]Viper 500ESP Alarm
Build Date: 8/23/00 (Kansas City Plant)
-AR
Take out the air silencer, give's you even less restriction and better than FIPK IMO. Still looks stock too!
Here's the link:
http://www.fordf150.net/howto/htairintake.htm
'01 SCrew 4x4 XLT 5.4L
Here's the link:
Jackal- Where is the snorkel silencer in the fender? IS the the little bellshaped tube that is ust sticking into the side of the fender? or is there something else?
Thanks!
Tony
Thanks!
Tony
Has anybody done both of the mods to their airflow setup (removing second half of airbox and removing the internal silencer elbow)
I'm wondering how loud it is before I cut it out of the external compartment. Can someone whose done this elaborate?
thanks
thanks
I've done both...it's not that loud...even with the hood up. I'm only talking about stomping it and getting the rushing sound...it's silent during actual driving. I cut the fender side of the airbox at the point where it starts to taper so it acts as a heat / moisture shield.
-AR
-AR
I picked up the Fernco, but i'm not really satisfied with how it installs. Is there a way it can be made to fit better into the existing fender hole? I suppose you enlarge the fender hole to fit the Fernco, and i suppose it doens't make a whole lotta sence to reduc back down to that size either and have it fit inside the hole. Mine fits pretty good except for on the under side it's not totally tight against the fender wall. I know it really isn't a major deal, just curious i guess.
Tony
Tony
Hey man, the Fernco should fit PERFECTLY OVER the hole. Here's what I did. Take the fender side of the airbox out, remove the snorkle, take one of the rings off of the Fernco, and leave one on...slide the Fernco way up on to the end of the airbox making sure the other ring is on this side, reinstall the airbox into the truck, drop in the K&N. Now, work the Fernco down the airbox toward the fender opening, until it firmly seats tightly against the fender. It should seal all the way around TIGHTLY, with no deformation of the Fernco at all. It helps to get both hands on it, and force it against the fender, then tighten the ring down TIGHT. After about 30 of messin' with it for the first time, it should fit perfectly. Just lift up on the airbox so as to tilt it upward, and push the airbox away from the fender, and push downward to position the Fernco over the hole. It won't move, once dialed in properly. Check it to make sure it's still perfectly round, and seals the hole. After a while, you'll get it...I could probably do it again in about 5 minutes TOTAL. Just recheck it every few days for a week or two to make sure you got it right, but it won't hurt anything otherwise, even if it does open up to the inside of the engine compartment. I ended up cutting off my airbox all together a few weeks ago and it really doesn't make a difference. Shoulda left it alone, but it somehow stays cleaner this way. See, with the Fernco, you can take air in, though the entire fender area, when before, it was restricted, AND only allowed air in from the extreme outer part of the fender. It also would help to remove the small plastic trim from between the bumper, and the headlight on the driver's side. If you spend some time examining this whole area, you'll see that the air would rush straight into the fender area with this piece removed. Hope this helps.
-AR
-AR
Thanks Jackal, i'll keep messing with it. Like i said, it's really not bad, so i'll just mess around with it some more and it should be good! Thanks again.
Tony
Tony
<font face="Verdana, Arial" size="2">Originally posted by BJays Red 150:
About that "noise" when you hit the throttle...
It's with that K&N, that when you hit the gas, the butterfly opens up and the engine SUCKS in much much air. The noise is the more air moving through the filter faster than was before.
At least, this has been my experience. I put the K&N in at 5K miles and just cleaned it at 20K ( didn't need it, I'm just ****). I also massacared my airbox, exposing the filter. gave me a little more low end torque resulting in a little better pickup
</font>
</font>
Take the whole intake out from the fender, to the throttle body. Remove the elbow silencer, (I assume you've seen the tech. article on this) take the fender side airbox half off and either cut it even with the two feet (pegs) on the bottom, or at the end, where it starts to taper down. Reinstall, and drop in K&N. Enjoy.
-AR
-AR
