Synthetic Oil in 302
Old Jun 1, 2001 | 11:46 AM
91Bronco's Avatar
Question Synthetic Oil in 302
I just put a rebuilt (Jasper) 302 in my 91 Bronco and have been considering using synthetic oil. I've been using Mobil 1 in my wifes 99 Expy since it had 500 miles on it with out any problems. However, I started using Mobil 1 in my bronce when it had 40K on it and at the time I replaced the Engine, it was leaking oil out of every seal that the oil touched. Did I wait to long to start using synthetics? Are the older engines just not very compatible with synthetics? Will the seals in the Rebuild be more compatible?
I do know that I got 1.5 Mpg better with the Synth than I did with the Conventional and would like to consider using it again. Any inputs would be helpfull.
Old Jun 3, 2001 | 07:43 AM
Winkelhawk's Avatar
Post
Synthetic oil will flow to leaking more easily than regular motor oil. When I install a new motor in my 85 Bronco, I had no problems with leaking when using synthetic oil.
Old Jun 3, 2001 | 10:31 AM
91Bronco's Avatar
Post
Thanks for the reply Winkelhawk. Do you still have the 85 Bronco? How many miles on the new engine? Are you still using the Synthetic oil?
