fuel system codes
Old May 18, 2001 | 11:17 AM
scuberdiver's Avatar
Unhappy fuel system codes
I keep getting a code p-1451 from my 97 F-150. The local dealer advised me to change the "evap canister vent soleniod", which I did. But the code returns.Has anybody gotten this problem and what was done to fix it.
Old May 19, 2001 | 11:12 PM
Nomopar4me's Avatar
Post
which solenoid did they give you? the one in the engine compartment or the one in the A$$ end of the truck?
sounds like a wiring concerrn if they gave you the right one..
Old May 20, 2001 | 12:54 AM
Unhappy
they sold me the solinoid for the evap canister
my engine still runs fine and if i use the code reader to cancle the code after its been running for a bit it stays off
Old May 20, 2001 | 12:56 AM
Kelly's Avatar
Post
scuberdiver,
What code scanner did you buy? Did you get in Canada? If so, from where and how much did it cost?
My truck is pretty much out of warranty, and I've been thinking of getting a code scanner.
1998 F-150 XLT 4x4 SC/SB 4.6L, Auto., 3.55LS, TTP, blah, blah, blah
All the info is at http://www.fordf150.net
Old May 20, 2001 | 01:15 AM
Post
By the way thanks for the replies.
For Kelly , I have the Actron obd 11
reader from canadian tire it was 300 after taxes.But i had to go to the net to find the explanations of the codes. I have the site on my computor at home not here. Also the is a site that has softeware and a cable for your laptop or desktop and it gives you tons more info like a guage display and stuff.I you want the url's e-mail me at scuberdiver@hotmail.com and on tues i can sent them to you.
Old May 24, 2001 | 05:55 PM
Post
just those who want the links for the code readers
http://www.obd-ii.com/codes.asp
Old Aug 18, 2006 | 05:27 PM
Crono1996's Avatar
obd scanner code power train 1451 " evap canister solenoid"
I keep getting the same code, a p-1451 code from my 2001 F-150 5.4 liter. I did replace the "evap canister vent solenoid" was well. I deleted the code and it the check engine light came back on, with the same code. The truck doesn't run any different then it normally did. I was just wondering if anyone new how to fix it, or if anyone had any wiring skematics for it. Please help me.
Old Aug 19, 2006 | 07:24 PM
Thumbs up Fuel codes
I had the same problem with my 97 4.6. I did some trouble shooting and found a broken wire from the canisters to a conector on the drivers side engine compartment. I recomend replacing the whole length of wire. I found several pin holes in the wire along the way to the front of the truck. It is common to poke holes in the wire to check for conductiving, and I figgure there was a problem from the factory and they used this method to find a problem.
good luck
Ric
Old Aug 20, 2006 | 09:31 AM
projectSHO89's Avatar
Just remember that the CV solenoid is the one at the rear of the truck, not the EVAP purge valve under the hood adjacent to the green service port.
Check the CV solenoid's resistance for the proper value, replace if open. Check for VPWR at one to the CV solenoid connector pins - should be hot with ignition in RUN. Check continuity of the other connector pin back to the PCM (look up proper pin in schematic).
Steve
