Airbox mod's PLEASE HELP!!!
Old May 11, 2001 | 01:38 PM
JMC's Avatar
JMC
25 Year Member
Post
Here is what I did. Should cost less than $50.00. I already had the K&N filter.
http://www3.sympatico.ca/jmc.chartier/air1.html
Regards
Jean Marc Chartier
SEE us play;
http://www.F150world.com/michapter/
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks, MAC 8.8 Axle Girdle
BFG 285/75 R16 MTs,
Borla Cat Back, Hedman Headers,
Custom air intake system with modified
air box, Ported Throttle body,
Shortened MAF sensor tower,
K&N air filter,
Superchips
Old May 11, 2001 | 04:22 PM
SilverFlareSide's Avatar
Post
The filters aren't interchangable. Sorry. I sold my filter to a friends dad who just wanted a filter cheap.
Old May 12, 2001 | 12:25 AM
2winturbo's Avatar
Question Airbox mod's PLEASE HELP!!!
I have the K&N filter installed into the factory airbox. I have also tried the poor man's FIPK that is listed in the tech articles section of this site. Where you remove part of the airbox and install the K7N exposed into the engine compartment. I switched back to see if I can notice any difference. Has anyone else tried this and did they get any results? Is it harmful? Is there a way to direct cool air from the fender opening towards the exposed filter or should I just bite the bullet and buy a FIPK?
Old May 12, 2001 | 12:30 AM
2winturbo's Avatar
Post
One last thing....does the K&N filter that drops into the factory airbox work with either the K&N FIPK or the AIR Raid or Air Force systems...Would hate to waste the $50 bucks! When gas is $2.00 a gallon...I need every dime I can get for my 50 mile a day hike to work.
Old May 17, 2001 | 01:20 AM
Matt90GT's Avatar
Post
Another option:
http://www.fordf150.net/howto/htairintake.htm
Old May 17, 2001 | 07:43 AM
white elephant's Avatar
Wink
don't waste your $ on an fipk! i already did(notice my sig). what i did cost me virtually nothing, looks great and has more benifits than any FIPK! Simply remove the silencer from the end of your air box. Cut a piece of 3" pvc long enough to go into the fender. dremel or file both ends to get a good fit onto the air box and most importantly into the fender(it doesn't have to be perfect). sand and paint the plastic if desired. this is the good part... use an inner tube or vulcanized rubber roofing material to wedge into any air gaps. some quality glue may be needed. trust me, if you do it right it looks good and works even better. you get the benefit of cold air and a larger intake opening. unlike an fipk it will equal more noticable power across the ENTIRE rpm range, better milage and best of all it won't cost you more than $10. it has no detrimental effects.
good luck and enjoy!
98' 4x4 S/C F-150 Flaireside, ORP, K&N FIPK(REMOVED!!) SAVE $, AIR BOX MOD RULES
Old May 17, 2001 | 11:53 AM
tfratzke's Avatar
Thumbs up
I agree with Matt90GT & white elepahnt. These two very simlar solutions are a much better alernative to the FIPK. You get the cold air intke, it's cheaper, & you don't have to worry about the the stupid filter falling off the FIPK like some people.
i did a mod on my '93 Taurus SHO very similar to this and it works excellent.
Tony
'01 SCrew 4x4 XLT 5.4L
[This message has been edited by tfratzke (edited 05-17-2001).]
