Door Cracks
Old Jul 25, 2002 | 06:45 PM
Black Dawg's Avatar
Unhappy Door Cracks
I know this has probably been beaten to death but im curious to know if anyone has been able to get ford to pay for the door crack problem? I contacted them today and the CSR told me that there hasnt been enough calls about door cracks and that nothing was being done about it. I went to my local ford dealer today and looked at some used f150s and 3 out of the 4 had door cracks.
Can anyone give me anymore info on whether or not I may be able to get ford to fix this?
Thanx
Black Dawg
Old Jul 28, 2002 | 06:49 PM
Copes98F150's Avatar
door cracks
Are you talking about the cracks in the door just outside the bottom corner of the window on the side closest to the handle ?
I had to have a door repainted when I got hit, and the body shop welded that spot ..... no problems since with that door, but the other one is just as bad !
Good luck with the dealership or Ford .... they never want to fix any body problems for free !!!!!
Later
Brian
Old Jul 28, 2002 | 08:05 PM
Rockpick's Avatar
Moderator &
I think there was a TSB issued for the door cracks. Might try searching the forums (using the search) to see what you can find.
RP
Old Jul 28, 2002 | 09:49 PM
kpaton's Avatar
I was able to get Ford to pay to fix mine. I was two days from bringing it into the bodyshop when my Mustang started having problems and had to cancel the repair on the truck. I didn't reschedule because I started to become concerned that having the door repaired and repainted might be worse than the 1/4" crack.
Old Jul 29, 2002 | 05:35 PM
Seapig's Avatar
TSB's
I have a 1997 that has been in storage for 5 yrs, and have looked up all the TSB's for it since I got a 7 yr warranty for it.
Out of the 616 issued for my year, there are 7 that have to do with door cracks. Here is just a sample:
Service Bulletin Number: 98-4717
Bulletin Sequence Number: 712
Date of Bulletin: 09/98N
HTSA Item Number: 607127
Component: STRUCTUREOOR ASSEMBLY
Summary: VEHICLES EXHIBIT CRACKS IN DOOR SHEET METAL AT LOWER REAR OF THE WINDOW OPENING NEAR BELT MOLDING. *AK
The other TSB's have to do with other places on the door.
Hope this helps and good luck with your dealer.
Mike
