advantages of EFI over carb?
Old May 13, 2001 | 05:49 PM
Donate54's Avatar
Post advantages of EFI over carb?
what are some advantages of fuel injection over carburation? my truck (not a daily driver) might get a new engine (5.8L) in about a year and i was wondering if i should keep the efi, or if i should slap in a 4 barrel carb? suggestions? opinions? any input is appreciated, thanks!
1989 F-150 XLT Lariat: 2WD 302 5spd[*]Performance Accessories 3" Body Lift[*]33x12.50.15 BFG A/T's on 15x10 AR Rims[*]Rancho Steering Stabilizer[*]Rancho RS 5000 Shocks[*]K&N Air Filter[*]Gutted Cats with Straight Pipes For Now...
Go Full Speed or Go Home!
Old May 13, 2001 | 07:17 PM
JA4x4's Avatar
Post
basically
EFI: better fuel economy
and truck will run at extreme off road angles
Carb:low tech, no BS computer
easy to fix
more power too depending on carb
Old May 13, 2001 | 07:40 PM
Dennis's Avatar
Post
Well, I had an '87 with the 5.8L and let me tell you, it SUCKED gas. No, let me restate that. It GUZZLED gas. It GUZZLED it and spit it out.
I can think of only two reasons to go with a carb. The EFI is shot and will cost too much to repair and/or you want to put a huge carb on it to get more power.
I have a feeling that you'll also need a different intake manifold, air cleaner, throttle linkage, and not sure if the tranny is computer controlled on your truck or not, but I'm guessing you'll need some kind of linkage to the tranny for downshifts (kickdown?) if it's an automatic.
The worst part of going with a carb is you may not be able to pass an emissions test if that's required where you are.
I dunno. I think sticking with the stock EFI would be a lot easier.
