OBD-II scan tool - Getting a STEADY light ?????
I hooked up a OBD-II scan tool to the connector and I'm getting a steady light ? Ford said it maybe a bad ground! Any suggestions????
Thanks,
Bob
Thanks,
Bob
What all can the scan tool do?
and how much does it cost?
97 F150 Longbed V8 4.6
K&N air filter
K&N FIPK tech MOD & removed elbow silencer
Tires: Yokohama 265/75/16 Geolander AT+
Hyper white xenon bulbs
Bedliner and raven shell
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
K&N air filter
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
<font face="Verdana, Arial" size="2">Originally posted by moose-man:
</font>
</font>
It looks like what you have is "not" and OBD II Scan Tool.
The cheapest one I have seen was $149.00 and it provides a number for the bad code if any are present.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Front Sway Bar Bushings, 265 70 16 tires, Rancho RS9000 shocks,Expedition Center Console
T Ellenberger
can you tell me more about this tool?
K&N air filter
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
K&N air filter
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
I will try to get the brand and part number but, I have seem them at AUTOZONE stores in this area for $149.00.
The J C Whitney scanner referenced above looks to be an OBD scanner; not an OBD-II scanner.
