WRONG RADIATOR AND DEALER WON'T REPLACE IT TRY THIS
Old May 2, 2001 | 04:56 PM
36racin's Avatar
Lightbulb WRONG RADIATOR AND DEALER WON'T REPLACE IT TRY THIS
YOU THAT HAVE THE WRONG RADIATOR AND THE DEALER IS GIVING YOU A HARD TIME ABOUT IT. CALL OR EMAIL YOUR LOCAL BBB ( BETTER BUSINESS BUREAU). FILE A COMPLAINT WITH THEM STATING YOU PAID FOR A CERTAIN EQUIPPED TRUCK AND THAT YOU RECIEVED LESS THAN THAT AND THE DEALER WILL NOT FIX THE MESSUP. THE BBB WILL THEN CONTACT THE DEALER AND SENT THEM A COPY OF THE COMPLAINT. WHAT THIS DOES IS PUT A BAD MARK ON THE DEALER AND IT MAY JUST BE WHAT YOU NEED TO GET THE RADIATOR REPLACED. SOME PEOPLE DO CHECK THE BBB FOR COMPLAINTS BEFORE BUYING CARS AND WILL SHY AWAY FROM ONES THAT HAVE COMPLAINTS.
IF YOU GET YOUR RADIATOR REPLACED THEN THE DEALER WILL REQUEST THAT YOU PULL YOUR COMPLAINT FROM THE BBB AND THEN THEIR RECORD WILL BE CLEAN AGAIN (MAYBE). IT'S JUST A SUGGESTION. IT MAY WORK AND IT MAY NOT. BUT WHAT HARM CAN IT HURT??????
