HELP? anyone know this code?
Old Apr 30, 2001 | 05:09 PM
F-trucks's Avatar
Post HELP? anyone know this code?
I have a 97 FORD F-150 4.6 engine 4+4 super cab my check engine light just come on and i have a OBD11 scanner i paid $400.00 for it says trouble code P1150 MANUFACTURER/ MANUFACTURER SPECIFIC/ SPECIFIC POWERTRAIN/ POWERTRAIN TROUBLE CODE this is the way it says exactly on my AUTO X-RAY digital scanner i looked in my haynes repair manual an there was no trouble code like that in it does anyone know what this code means? or is there a website i might could find out any help will be appreciated THANXS!
Old Apr 30, 2001 | 07:20 PM
01sport's Avatar
Post
From the '01 Ford manual
P1150-Lack of HO2S-21 Switch, Fuel Trim at Limit.
Description-
The HEGO Sensor is monitored for switching. The test fails when the HO2S fails to switch due to circuit or fuel at or exceeding a calabrated limit.
Possible Causes-
Electrical
*Short to VPWR in harness or HO2S
*Water in harness connector
*Open/Shorted HO2S circuit
*Corrosion or poor mating terminals and wiring
*Damaged HO2S
*Damaged PCM
Fuel System
*Excessive fuel pressure
*Leaking/contaminated fuel injectors
*Leaking fuel pressure regulator
*Low fuel pressure or running out of fuel
*Vapor recovery system
Induction System
*Air leaks after the MAF
*Vacuum leaks
*PCV system
*Improperly seated engine oil dipstick
EGR System
*Leaking gasket
*Stuck EGR valve
*Leaking diaphragm or EGR
Base Engine
*Oil overfill
*Cam timing
*Cylinder compression
*Exhaust leaks before or near HO2S(s)
Old Apr 30, 2001 | 07:55 PM
willards1's Avatar
Lightbulb
From my Haynes 97-00 Repair Manual: P1150- Lack of Upstream Heated Oxygen Sensor (H02S21) Switch, Adaptive Fuel at Limit (Bank 2)........Hope this helps.
2000 F150 SuperCab/Long Bed 4X4 ORP; 4.6L Engine; 5 Speed Manual Transmission; Hellwig Anti-Sway Bar; Westin Step Bars; Air Raid FIPK; BedRug; SNUGTop TruckCap
Old Apr 30, 2001 | 08:07 PM
ScrewKing's Avatar
Post
I just went through this same thing with my 91 Explorer. Changed the sensor(original) and my mechanic drove it for two weeks to see if the check engine light would come on again. It didn't untill my wife drove it home and it came on and idled rough. Took it back and discovered the fuel pressure regulator was shot. It was so intermittin that the light was off when I drove it back to him untill 2 miles from his shop and then came on. But the engine was idling so smooth when I got there You'd never know anything was wrong. Had it hooked up and saw the fuel pressure jump from 32 lbs to 75lbs. and back again.
01 Kingranch, 4x4, 5.4, Estate Green w/Arizona Beige two tone, Limited slip,Skidplates,Moonroof,Trailer tow, Cargo cage, All the Goodies! Add ons; Bedrug, 9005 Fog lamps
