Possible for self-made tubing for intake?
Old Apr 25, 2001 | 03:05 PM
fast54triton's Avatar
Post Possible for self-made tubing for intake?
Is it possible to take plastic tubing and make your own FIPK? My cousin talked about it, he did one for his Dakota with thw 3.9l v6. Would this work at all?
Former fast46triton
2001 Ford F150 XLT Supercab, Silver two-tone with deep wedgewood blue on bottom, 5.4l Triton V8, 3:55 LS Gears
Upcoming mods!
1) Superchip
2) FIPK
Old Apr 25, 2001 | 05:25 PM
cyclone's Avatar
Lightbulb
Fast54Triton,
Check out the thread below -- it shows a picture of the one Neal did. Based on his performance numbers, I have to imagine that it performs about the same as some of our "off-the-shelf" ones. Hope this helps.
https://www.f150online.com/f150board...ML/001354.html
Old Apr 25, 2001 | 05:45 PM
Neal's Avatar
Cool
HI!... GUYS : Thats nothing!LOL! You should see the true RAM AIR set-up that I'm designing right now. I'm going to start building the REAL one in about a month. Right now all I have is the plans and a primitive prototype. This will be a set-up that as far as I know, no one has thought of or built. You must have electric fans though for you to do this. You need the room. I'll let you guys know how it works out and mabet some pics.
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, PERMA-COOL external tranny filter, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings.
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.52E.T * MPH - 93.73 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
Old Apr 25, 2001 | 05:53 PM
JMC's Avatar
JMC
25 Year Member
Post
Fast,
Check out; http://www3.sympatico.ca/jmc.chartier/air1.html
I made this for about $50.00
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks, MAC 8.8 Axle Girdle
BFG 285/75 R16 MTs,
Borla Cat Back, Hedman Headers,
Custom air intake system with modified
air box, Ported Throttle body,
Shortened MAF sensor tower,
K&N air filter,
Superchips
Old Apr 25, 2001 | 09:49 PM
Talleywacker's Avatar
Suspended For Violation of Vendor Rules
Post
Neal,
I think I know what your doing then if you need that much room ... I'll keep it secret
Old Apr 26, 2001 | 07:54 AM
Y2kXLTSport's Avatar
Post
JMC
When I click on the pictures (to hopefully make them larger) I get an error message about not found. Can I get the pictures larger so I can see exactly what you did?
2000 F-150 XLT Sport, Silver 4-door Supercab StyleSide
Short Bed (Only way to fit in the garage)
17" Sport Wheels with BFG tires, 3.55 R, 4.6l V8, Auto (First one in 20 years)
In-Dash Single CD Player, 60/40 Split bench dark graphite
Mods So Far
K&N Filter, Gatorback Spray-In Bedliner, Llumar ProShield Window Tint
WMS Velocity Tube (removed due to hum), Black Westin Step Bars, Lund Trident Hood DeflectorFlowMaster Delta Flow 50 muffler in place of stock
Future Plans
Superchip, Upgraded Speakers/Stereo
