water pump nightmare
I am guessing that Haynes is saying that due to covering both the v6 engines as well as the v8's.
5.4 will be the same I would think since they are all supposed to be Windsor engines.
Maybe there are two different builds on the 4.6 engines I just don't know on that.
I determined mine the first time by purchasing the replacement pump and simply threading my fingers around the end to see which way was going to tighten. I found out it was normal thread and the hard part was finding a way to hold the fan to break it loose.
A lawn mower fanbelt resolved that issue quite handly.
I am also finding the Haynes manual doesn't describe very well where sensors are located on the 5.4 engine as well.
I am thinking it is better to ask here than to RTFM
tom
tom
Rotties150
Thanks for the offer on the heater core stuff but it's not needed. Thankfully it's not leaking yet. I was just basing that on the poor condition of my cooling system. Secondly I own a real 2 volume Ford factory manual for my year of truck. Bought it from a Ford tech on this site for a very good price when he purchased a bunch of old shop manuals some dealer was throwing away. So all in all I have 3 repair books on one truck, just need a cd/dvd now.
Someone else has said this already but I agree that the hardest part is finding something to hold the WP with. The v-belt idea is a good one ( not sure how it worked). Then someone else said take a scrap piece of metal and drill two holes the distance of the bolts in the WP pulley and install that on there. Me, all I did was hold one bolt with a boxed end wrench against another bolt and had someone else use a pipe wrench and hammer. Just took a couple of taps and it was loose. The real pain was getting the old WP to release from the cavity it sits in. Mine was really stuck and I demolished a 2x4 smacking that thing off. I cleaned the cavity out as best I could but it may or may not leak. Time will tell I guess.
Best of luck to all who attempt this project.
I bought a water pump tool kit at a local NAPA parts store. Comes with a holder tool and a wrench, makes it real easy once you turn it the right way.
(Of course I already mentioned that in the 1st post in this thread.)
