Code question
Old Jun 16, 2002 | 11:36 PM
78mphgpr's Avatar
Code question
Can any one tell me what code #'s 0171 & 0174 mean. It is for my 98 Navigator. Thank you.
Old Jun 17, 2002 | 01:49 AM
KYFordFreak's Avatar
Yeah I can tell you but it's gonna cost ya $5 bucks a code!!! Just kidding...LOL.
171= system to lean ( bank 1)
174= system to lean ( bank 2)
Now your left wondering what the heck that means. I can not tell you exactly what it means but I can tell you what I know. Lean is not good, lean causes your motor to run hot and cause detonation. Have you heard it pinging lately?
Possible causes can be:
clogged injectors
O2 sensor's
timing is off (shouldn't be as it's controlled by the PCM)
other fuel system problem
I suggest having a good mechanic/tech look at it. Search this site, this has come up before.
Old Jun 17, 2002 | 06:55 AM
TexfordD's Avatar
change fuel filter,first
Old Jun 17, 2002 | 02:01 PM
dloreanwiz's Avatar
lean
if your engine is running lean it means there is to much fuel in the air/fuel ratio because there is an optimum ratio if it running lean expect detonation and increase engine wear,and if your running rich to much air
Old Jun 17, 2002 | 02:37 PM
JMC's Avatar
JMC
25 Year Member
dloreanwiz,
Uncross those wires. Lean is not enough fuel and rich is too much.
Check intake air system for leaks, obstructions and damage.
Check air cleaner element, air cleaner housing for blockage.
Verify integrity of the PCV system.
Check for vacuum leaks.
If all of these check out the next thing to check is the MAF. That should be left to a tech.
regards
Jean Marc Chartier
