Mass air sensor
Old Apr 3, 2001 | 06:18 PM
jeffrandol's Avatar
Post Mass air sensor
Hey Folks, I am going to order a superchip but I am thinking about ordering a better Mass air Sensor as well. Has anyone upgraded this? If so did it work, what size and where did you buy it? Thanks for the help everyone!! Helluva a site here!
Jeff Randol
2000 Ford F150
Ext. Cab 4x4 Lariat
5.4 Auto, Off Road Package, Fully Loaded
& lovin it!!
MODS: KN Air Filter
Glasspack exhaust
Upcoming: AMSOIL Dual Oil filter system, FIPK, Fiberglass Topper, Spray-In Bedliner, Wood Dash Kit
Old Apr 3, 2001 | 09:22 PM
Neal's Avatar
Cool
HI!... JEFFRANDOL : You can get a "PRO-M" MAF from a company called PRO-FLOW. These are the most commonly used aftermarket MAF's. They are 80mm, the same as the stock MAF on your truck but with a revised sampling tube. This causes them to flow more air. If you install a aftermarket MAF on your truck, make sure you get a SUPERCHIP or get your current SUPERCHIP re-programed for it. Aftermarket MAF's are known for leaning out your air fuel mixture. This can cause severe engine damage if it is run like that for a long period of time. In my opinion you will only gain about 3-5H.P with a aftermarket MAF on a basicly stock engine. They give great H.P increase on supercharged engines or naturally asperated engines with a ton of mods, like mine. If you want 28H.P and 46FT/LBS of torque then go get yourself a SUPERCHIP from MIKE TROYER. After the install you won't be disapointed.
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings.
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
Old Apr 8, 2001 | 06:38 PM
tobyk's Avatar
Post
hello,
I have tried the MAF sensor from Granetelli.
I noticed a difference in performance on the freeways (not from dead stop). It was an 80mm sensor and my exhaust got noticeably louder. I don't think, however, that its worth $320, but I think it'll make a good companion with a high performance chip.
