Improving MPG?
Old Mar 29, 2001 | 03:51 PM
LEO SuperCrew's Avatar
Post Improving MPG?
To all you folks out there who take the time to tinker and tune your engines and then post your comments on this board. Thank You! I have obtained some valuable information from this site. What can I do to get more MPG out of my 2001, SuperCrew, 5.4 4X4? Will a FIPK help? Will an FIPK + something else help more? Any info would be greatly appreciated.
2001(Gen I) SuperCrew XLT 4X4, Solid Toredor Red w/Running Boards, Medium Graphite Gray Capt. Chairs, 60/40 Split Rear Bench, 5.4L EFI, 17" 10-spoke Wheels, Class III Trailer Tow Pkg, 3.55 Limited Slip, Sliding Rear Window, AM/FM Cassette w/ 12 Disc CD Changer
Old Mar 29, 2001 | 04:49 PM
01X's Avatar
01X
Post
The fipk will help and an aftermarket exhaust will do even more. You will probably get around two to possibly three mpg improvements. The best thing to do is to drive with some common sense and civility.
Old Mar 29, 2001 | 06:02 PM
JDF's Avatar
JDF
Exclamation
Just keep in mind your expense ratio.
A truck that now gets 15 mpg driven 12000 miles will use 800 gallons of gas. At $1.50 a gallon that's $1200.
If you now get 17 mpg you will spend $1060.
How much are you willing to spend to save $140? Figure your own estimates first.
Old Mar 29, 2001 | 06:45 PM
F150Sven's Avatar
Cool
Something that I've found helps fuel mileage is to use the panel/vent setting for the climate control. This keeps the a/c condenser from running. It will run if you use any of the defrost settings, and of course when the a/c is in use. I gained 1-2mpg just by doing this instead of running around with the defrost on for heat. This ones a cheapy, too.
Another way that has been discussed is replacing the stock belt driven cooling fan with electric fan(s). This reduces parasitic losses from the fan turning all the time, even when you're not needing it. This, though is another $200 fix for 1 or 2 mpg, but as with the exhaust and intake mods, you get the performance gains as well.
2000 F150 XLT 4X4 Off Road 5.4L Reg. Cab 3.55
Performance Enhancemets:
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
All of the above, plus
Sony C7000X HU
Cerwin-Vega SS2502 components(Front)
Blaupunkt PCxp573s(Rear)
Radio-delay mod
Other Enhancements:
Extang Black Max Tonneau Cover
Old Mar 29, 2001 | 06:47 PM
max mitchell's Avatar
Cool
Chip,FIPK, and cat-back = 1mpg ocassionally for me. How about a bedlid?
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
Old Mar 29, 2001 | 10:55 PM
DaveH's Avatar
Post
When do you see your best mpgs a tank. So far the highest i have gotten on a tank is 14.2 mpg. I mostly get though 12mpg mostly city also. My question is I have 1400 miles about how many miles on engine do you see best mpg 5,000 or more? Thanks
2001 F-150 5.4L trition,
Regular cab with 8' bed
XLT with Black Clearcoat
4x4 3.55 limited slip
factory cab steps
class III tow package
Factory ordered: 12/5
recieved: 2/22
Current Mods: Ford Plastic bedliner, Bug Deflector II
Old Mar 30, 2001 | 11:40 AM
JDF's Avatar
JDF
Talking
I got 15.8 combination on last tank. I am a very light foot driver. Not bad though.
2001 F150 XLT SC SPORT 4X4 FLARESIDE
* Black
* 4.6
* Auto
* awesome factory 10 spoke 17" wheels
* "MAN"ual shift 4x4
* 3.55 Limited slip
* Captains chairs W/console
* Factory tube steps
* Slider
Old Mar 30, 2001 | 02:39 PM
therock's Avatar
Post
All the mods i have put on my truck have helped my mpg alot.(17 mpg) Adding induction, exhaust, throttle-body spacer, and chip will help you out. My brother's 99 4.6(3.55 gears/auto) is getting 17 mpg mixed driving. The only mods: K&N air filter and Helix Power Tower. His next upgrade is a Borla Exhaust.
1999 5.4 F-150 R/C S/B Lariat
3.55 gears/limited slip
classIII towing
Captin Chairs
Mods:
K&N FIPK, Helix Power Tower, Gibson split rear exhaust,Jet Performance Chip.
Future mods:
75mm throttle body
80mm m.a.f.
super chip
Old Mar 30, 2001 | 08:36 PM
rus's Avatar
rus
Post
I average mid 15's now.I drive about 1500-2000 miles a week. I set my cruise on 72 and let her go. I use low octane gas.I installed a bedlid for security of items in back. This helped me gain .5mpg.I lowered rear 2 inches
this seemed to help but minimal.My mileage went up at 5000 miles. Can't explain why as my driving habits are the same as before.
Old Mar 30, 2001 | 10:42 PM
F150Sven's Avatar
Cool
My best has been a little over 16mpg, and that was earlier this winter. I'll be interested what I can do when the "summer blend" gas is back in circulation around here. I know I took about a 2mpg hit when they went to the winter blend. Since then I've added the cover, and it seems to help some. I'm at about 13,000 miles, now. I've heard people say that gas mileage will improve all the way into the high teens with the triton engines.
I'm content with performance and economy for now. I may look into an electric fan setup and chip later on though.
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
Sony C7000X HU
Radio-delay mod
Other Enhancements:
Old Mar 30, 2001 | 11:17 PM
jimwww's Avatar
Question
<font face="Verdana, Arial" size="2">Originally posted by LEO SuperCrew:
</font>
I really do not know why so many people get bad gas mileage with their trucks.. I am quite happy with mine. I recently drove to Tofino on Vancouver Island,BC Canada and I filled up before going over the mountain and then I came back to the exact gas station (250km / 155 miles) I refilled and it was 30 liters to top it off (6.6 gal) which means I attained 23.6 miles per gallon with my 5.4 liter 2000 4wd S/cab XLT. For such a large engine and 4400 lbs and 10,000km (6000miles) on it I don't expect more. The road I drove on is far from flat...up/down all the way (no stop signs though)
In the city it is less..but it is a hwy truck.
Old Mar 31, 2001 | 12:31 AM
acadianbob's Avatar
Post
i'm always amazed by all of the gas mileage talk . . . the window sticker estimates should have been fair warning . . . these are big trucks with lots of mass . .that takes fuel . . . one message made a lot of sense, why spend big bucks on mods that will never return investment in gas mileage unless it is the power you are after . . and if you use that power, the mileage will never come . . . the best bet is to drive sensibly . .accelerate modestly and, above all, anticipate traffic and lights to keep from stopping . . you want to maintain your momentum . . i'm getting 17 mpg in daily suburban traffic in fairly cold weather (30 degrees) with my V-6 5spd 4x4 . . but i baby it . . another driving style could easily run this down to 12 mpg . . .
Old Mar 31, 2001 | 06:34 PM
OMEGA5's Avatar
Smile
Believe it or not, the first time I checked my mpg was last night. Filled up and did the math; 17.6 mpg. That's around town and East Tennessee 2 lane mountain curves. Not bad and should get better since my truck only has 5,700 miles on it.
98 NASCAR Special Edition
1OF600 w/ Auto & Tonnaue
K&N FIPK
Hypertech Power Prog.
JET 180 degree thermostat
Hellwig SportTech swaybar
Gibson SuperTruck CatBack
Pilot SS Resonated Tips
Shelf-It overhead storage
Hella FF300 Fog Lights in grill.
Old Apr 2, 2001 | 01:04 PM
dgreene's Avatar
Post
no way! what were you smokin'?
<font face="Verdana, Arial" size="2">Originally posted by jimwww:
</font>
Old Apr 2, 2001 | 01:21 PM
BigRedF-150's Avatar
Post
Jimwww,
You better check your liters to gallons conversion again. 30 liters does not come to 6.6 gallons it comes to 7.8 gallons. Multiply the number of liters by .26 . So your mileage was 19.8 not 23.6.
