what kind of oil do I use?
It does use 5w30 if it's 2000 model or older, 2001 are 5w20.
Do a search for 'oil' in engines, and you'll be surprised how much discussion is available.
Bambino Online
Owners Gallery Truck #179
1999 reg cab/short box/ORP - 3.55; 4.6l 5sp; factory snapless tonneau; twin 6" kicker sub tubes; Custom Exhaust; Mobil 1 5w30/Motorcraft FL820-S
Bambino Online
AMSOIL 5w30
http://www.amsoil.com/products/asl.html
Look at this. You will love it.
With Amsoil you can't go wrong. Let me know what you think, maybe I can help you. Good Luck
Ruger's F-150
E-MAIL ME:
pureamsoil@bigfoot.com
MY HOME PAGE:
PureAmsoil
Ruger's F-150
E-MAIL ME:
MY HOME PAGE:
PureAmsoil
Hey, ruger-dfw. I read on one of your discussions that Amsoil pure synthetic oil can be ran 25k without being changed. I am very interested in how available this oil is and how much it costs. I am also skeptical on how this oil can go this long without breaking down. I haven't heard of any other oil that can be ran this long. Post me some info.
I am not sure if I am correct but I am sure someone told me that shanging the type of oil you use in your engine after a few oil changes is very bad for your engine. Let me know
Jimmar
Jimmar
JLetson2001,
Go here and you will find the break down.
Q. Will AMSOIL Motor Oils void the warranty of a new vehicle?
A. Absolutely not! Manufacturers’ warranties are based upon the use of oils meeting specific API Service Classifications, for example, SJ/CF. (AMSOIL lubricants meet the current API Service requirements and, thus, are perfectly suited for use in any new vehicle without affecting the validity of the new vehicle warranty
http://www.amsoil.com/drain.htm
Q. Will AMSOIL Motor Oils decrease oil consumption?
A. Yes. When used in mechanically sound engines, AMSOIL Motor Oils can reduce oil consumption. Under test conditions, a reduction of as much as 42% was demonstrated for prolonged periods. However, this should not be taken to mean that AMSOIL Motor Oils are “cure-alls” for engines that consume oil because of mechanical problems.
Q. Is there a recommended procedure for changing to AMSOIL Motor Oils?
A. There are no special requirements; however, in older vehicles or those with high mileage, it may be advisable to use AMSOIL Engine Flush first. This will ensure that the engine is clean and free of any accumulated contaminants which might have an effect on the service life of AMSOIL Motor Oils. In all cases, it is good judgement to install a new AMSOIL Super Duty Full-Flow Oil Filter (SDF) every time you change oil.
http://www.amsoil.com/warranty.htm
I hope this will help. I changed my oil in my 99 Ford back in Aug, with all the heat and the oil look just as good as putting in.
Just replace the filter after 6 months and replace the oil that the filter keeps, than replace the filter and the oil @ 25,000 miles or 1 year witch ever comes first. Good Luck. Let me know what you think. Thanks
mobil 1 oil! mobil 1 filter. a magnet at the end of the filter also.
0w 30 in the winter months
5w 30 in the summer months
no problems 56,600 miles 4.6 liter engine.
getting ready for the pcv valve change.
1997 f150 xlt black extended cab 4.6, 4x2 auto limited slip
mercon v, k&n filter
load lok liner.
17 inch tires saw blade rims goodyear at/s
vent visors
nerf bars black
door crack drivers door
looking for front bush guard for future mod
load lok liner.
vent visors
nerf bars black
