Performancs Mods for 5.4V8
Old Apr 1, 2001 | 02:35 PM
Neal's Avatar
Cool
HI!... LIKELINUS : The FIPK filter kits give you about 14H.P according to dyno info I have seen, but count on a TRUE 10H.P increase. The SUPERCHIP will give you 28H.P and 46FT/LBS of torque on your 5.4. This has been proven over and over again on a "EDDY" current dyno.Go with the ASP power pulleys (2 PULLEY KIT). You will gain about 7-10H.P with these. The JBA headers will give you 17H.P on the 5.4. This has also been proven on a "EDDY" current dyno. If you do all the above mods then you should be making about 315-320H.p at the flywheel. Read my SIG below to see some other mods you can do. Hope this helps you out.
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings.
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
Old Apr 1, 2001 | 02:59 PM
LikeLinus's Avatar
Post
Neal, i appreciate the reply! Yeah i actually was reading your sig and a few others earlier to get a general idea of what i could do. I'd like to be somewhere in the neighborhood of 320 or so HP...that'd be great. That helped alot! Thanks.
Anyone else have suggestions.
Old Apr 1, 2001 | 04:11 PM
max mitchell's Avatar
Cool
Phase 1
A)Superchip
B)FIPK
C)properly engineered cat-back
Phase 2
A)4.10 gears
B)reduction pulleys(w/towing & trust weighed)
Phase 3 (if you need or can afford)
Supercharer
If charged: MAF,TB,headers
My opinion only
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
Old Apr 1, 2001 | 06:16 PM
Former Sponsor
Post
HI LikeLinus,
The others have provided some good feedback hre, I just wanted to comment briefly on what you can expect from the Superchip. As Neal mentioned, the maximum rated gains from the Superchip on the 1999 & newer 260-hp version of the 5.4 are 28 hp & 46 lbs./ft. of torque at sea level altitude. Your 1998 5.4 was rated at 235 hp stock, and will gain about 1-2 horsepower and 2-3 lbs./ft. of torque less than the later 260-hp. 5.4's gain from the Superchip, so it's pretty close.
In terms of what to expect the Superchip to make your vehicle feel like, it's going to feel like you just picked up about 10% more motor under the hood, is one way to express it. Not everyone lives exactly at sea level altitude where all manufacturers rate their products, so what you can expect from the Superchip at any altitude is about a 10%-12% increase over what you're making stock.
The JBA headers are definitely worthwhile, though most people do them later on, as they're a little bit futher down on the "bang-for-the-buck" list, just because they a bit more expensive than some of the other mods. But they're still very worthwhile, and will need to be a part of your package if you want to get to the 325hp level.
Take a good look at what Neal has doen to his truck, as he is at that kind of power level, and can tell you a lot about how to get there from experience.
Good luck!
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
Old Apr 1, 2001 | 09:36 PM
Dustoff's Avatar
Post
I went with the Superchip and drop in K&N filter. I have been considering a FIPK..but I am more than pleased with the Superchip/K&N combo.
2000 F-150 XLT, 4x2, 5.4L Supercab, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with super engine cooling/auxiliary transmission cooling HD package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, FORD black tubular cab steps, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil, build 7/2000
Old Apr 2, 2001 | 12:05 AM
LikeLinus's Avatar
Post Performancs Mods for 5.4V8
I've got an 98 extended cab 5.4V8. I'd like to start adding some mods as money permits. But i've got some questions on real world HP increase and what i should do/add and the order.
I've looked at the
Airforce 1 kit. They say around 14HP, what would i really expect?
Superchip. I'd do this after all the other mods, but how much HP with this?
Poweraid. They seem like some nice pullies, whats the HP rating on these?
and last
The JBA Headers. It says anywhere from 10-30? What is realistic?
What do you think my overall HP output would be if i had all these installed?
I'd also like to know some other mods that i could do! Please let me know everything and anything! I'd appreciate it. I'd ideally like to be putting out somewhere near 325hp, i dont know how realistic that is though?
