Flex Fan
Old Mar 27, 2001 | 09:22 AM
HandyMan's Avatar
Talking Flex Fan
I'm looking into replacing my stock radiator fan with a Flex Fan. It's probably not as efficient as the electric fan alternative but I can get a "bolt on" Flex Fan for less than $40. Does anybody have any experience with Flex Fans?
2000 XLT Ext Cab S.B. 4x2
4.2 L, 5 sp man, 3.55 gears
4 wheel discs (ABS x 4)
Jeraco Fiberglass cap
All Star bedliner
Old Mar 27, 2001 | 10:26 AM
eddiepreston's Avatar
Thumbs down
Yes, if you don't use a clutch a flex fan is real noisy!
2001 Super Crew Built 10/00 purchased12/00 Lariat 5.4 4X4 Bright Red,Tow Package, 1.42" Radaitor, Factory Steps, K&N air filter, A.R.E. LS II, Rear Seat Entertainment System, Sound System Upgrades, DRL'S, Vent Shade Vent Visors, Stampeede bug Deflector. Owner installed "Off Road Package" with custom made decal. Hope to upgrade soon to Gibson SS or Dual Sport!
Old Mar 28, 2001 | 12:50 AM
JMC's Avatar
JMC
25 Year Member
Post
HandyMan,
You might be wasting your money. Your truck has fan clutch which slows down your fan when it doesn't need it. The flex fan is designed to change the pitch of the blades when spinning at high rpm which reduces the drag. You will need to know at what rpm the pitch changes on the flex fan. The OEM clutch allows the fan to turn at 1500 rpm when the water pump is turning at 3000 rpm when not needed and min 2300 rpm when needed.
So at a water pump speed of 5000 rpm the fan turns at between 2500 and 3800 rpm. So if the fan starts to flex at 4000 rpm it is not realy needed.
Regards
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks, MAC 8.8 Axle Girdle
BFG 285/75 R16 MTs,
Borla Cat Back, Hedman Headers,
Custom air intake system with modified
air box, Ported Throttle body,
Shortened MAF sensor tower,
K&N air filter,
Superchips
Old Mar 28, 2001 | 08:47 AM
HandyMan's Avatar
Smile
Thanks for the feedback guys.
JMC, that's a great picture in your signature!
All Star bedliner
Old Mar 28, 2001 | 10:12 AM
JMC's Avatar
JMC
25 Year Member
Post
HandyMan,
Thanks but Jim Mc the Pinckney Pirate actually took the Picture. I just drove the truck.
Regards
Jean Marc Chartier
