Head Gasket replacement?
Old Mar 26, 2001 | 02:18 PM
rockycarl's Avatar
Post
Congratulations on your truck! Unfortunately, the head gasket is a problem on many 99' F-150's. Mine had the same leak repaired under warranty. The list of parts replaced is too large to list, but the invoice to Ford Motor Company was $1291.82. Luckily yours is still under warranty also.
Just do a search for oil leak under the engine board and you will find many topics on this issue.
Good Luck!
MY TRUCK:
99 F-150 4x4, 5.4 Triton, 3.55 gears, Amazon Green-Harvest Gold two-tone.
MY MODIFICATIONS:
Superchips Flip Chip
Lund bug shield
Window vent visors
17" Chrome ORP wheels
Clarion Pro-Audio in-dash CD
Connex 3300HP CB radio, K-40 antenna
Husky floor liners
Custom dual exhaust w/Flowmaster muffler and dual 3" chrome tips
Hidden hitch
K&N Filter
Extang tonneu cover
Rancho RSX Shocks
Tekonsha sentinal, inertia activated electric brake controller
Old Mar 26, 2001 | 04:09 PM
e007dw's Avatar
Smile
Thanks for the reply and advice!
Old Mar 26, 2001 | 05:24 PM
Neal's Avatar
Cool
HI!... e007dw : My truck (5.4) in DECEMBER of "99" had both cylinder heads replaced and head gaskets because of a blown head gasket on the passenger side. The 5.4's are known for blowing head gaskets on the passenger side. My truck is at my dealers as I right this because the driver's side head gasket has blown again! My tranny's tailstock is cracked and my driver's side power mirror motor is burned out. If you just bought your truck then definately check it for the dreaded door crack on the driver's door. It's usually right around the 90 degree black trim peice above the door handle. I've had my door replaced by my dealer already. Hope this helps you out.
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings.
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
Old Mar 27, 2001 | 12:09 AM
e007dw's Avatar
Question Head Gasket replacement?
I've just purchased a '99 F150 with the 5.4L V8. I picked it up 5 days ago - NICE TRUCK! It was a lease return with 32k miles and in excellent condition.
Okay, now the problem...
I noticed an oil spot on my garage floor underneath the engine compartment. I brought it back to the dealer I purchased it from and just got a call back about the problem. The service folks tell me that I have a bad head gasket. A bad head gasket?
Is this "normal" or common for this engine?
What should I do?
Thanks for your help.
