throttle cable
thanks speeder: but where do you put the ties or split shot---athe top of the throttle crank channel or at the end of the cable? don't want the cable to roll or pop off of its track/channel. dan/renegade
<font face="Verdana, Arial" size="2">Originally posted by speeder:
HI dgreene
You can use some plastic zip ties or some
lead split shot, the type used for fishing
hope this helps you out Larry.</font>
HI dgreene
I used a small bolt and nut and put them on the cable inside the passenger compartment. If you move the drivers seat all the way back you can get down there and see how the linkage works and there was movement before the slack was taken up. I could not find any adjustment under the hood so I went for taking out the slack.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Front Sway Bar Bushings, 265 70 16 tires, Rancho RS9000 shocks,Expedition Center Console
