Does WMS Velocity Tube use the stock size air filter?
Just wondering if it uses the stock size, whether it be K&N or paper. Thanks!
Tony
'01 SCrew 4x4 XLT 5.4L
Tony
From what I have read at their website and other postings, the WMS tube is used in conjunction with the stock air filter box, and stock-sized filter of course.
The snorkel inlet from the fender to the box is replaced with a larger (3") tube going into the stock airbox, then the 3 1/2" velocity elbow tube from the Mass Airflow sensor adaptor to the throttle body.
Here's the flow:
Incoming air pulled into the new 3" Inlet Tube, then into the stock Air filter box through the stock MAF sensor adaptor through the 3 1/2" Velocity tube to the Throttle body.
You might check with WMS and/or Ford to see if your warranty could be affected, as in "voided". I'm pondering the thought of installing one on mine, but the warranty question has me wondering to move forward with a purchase and installation. I've only 2500 miles on mine.
2001 F-150 SuperCrew Lariat
Black w/gray leather
4x2
5.4L
Towing package (with the 1.02" radiator . . . hmmmm?)
Modifications:
Gibson SideSwept Performance Exhaust
K&N filtercharger w/modified cold air box
******* fiberglass bed lid
Ventvisors
Hood deflector
Wish List:
Flipchip
Bed X-Tender
Billet grill
Clear corner lenses
Oil filter relocation
Factory air dam w/fog lamps and replacement headlight switch.
1.42" Radiator to complete the Towing Package!
Here's the flow:
4x2
5.4L
Modifications:
Ventvisors
Hood deflector
Wish List:
Flipchip
Bed X-Tender
Billet grill
Clear corner lenses
Yes, it uses the stock size filter.
1999 4x4 F250 LD XLT SuperCab 5.4L, 3.73, 4R100 trans.
Flowmaster exhaust, K&N, Superchip, WMS Velocity Tube, Rancho RSX shocks, Hellwig rear swaybar, Stull billet grille, PIAA Air Dam with 2-PIAA Pro80XT's (120W), 4-KC Daylighters (150W), Performance Accessories 3" Body Lift, 33/12.5/17 ProComp Mud Terrains on 17x8 American Racing Atlas Rims. Kenwood 7007 CD, Alpine 3342 Signal Processor, Alpine MRV-F353 5Ch. Amp, Pioneer TS-A6865 3-way speakers, MTX Thunderforms. CompuStar alarm/autostart.
Ok maybe its just me but can't we just go to JC Whitney and get a 90 degree mandrel bent 3.5" pipe and a small section of 3" straight pipe and bolt it on. This would cost $20 including the rubber connecters.
Kev
Kev
Kev, that is exactly what I'm going to do. Fasion my own. I want a cold air intake and want to position such that I'm drawing from somewhere other than directly under the hood, especially the top of the hood area where heat rises. I'll also use a metalic clad insulator around the intake tubing and airbox to keep the charge cool. Don't care if it's shiny chrome, that won't help with power output.
- Soon to be 2001 F150 Harley Davidson Special
- 1993 Mazda Miata, wifes car
- 1994 Harley Davidson Heritage
- 1976 Honda CB750K, Original
- 1965 Honda 305 Dream, Original
- 1971 Triumph Trophy 650, Original
- 1971 Norton Commando
- 1970 Honda Trail 90, Original
- Yamaha 500 Short Tracker, racing #69
- 1984 Yamaha Virago 1000, wifes bike
- 1981 Honda Passport 70, wifes bike
The filter really has nothing to do with the velocity tube. Your still using the stock air box and that's what the velocity tube attaches to. As for effecting warranty, there shouldn't be any reason that the tube would void the warranty, but, you have to remember that the dealers are cheap bast***s, and they'll try to get out of anything that costs them money. I'm taking my truck in soon to get a FQR engine installed, and I'll uninstall the tube and install the stock one just to avoid any possible confrontations. That and they would probably install improperly. It's a little tricky around the throttle body where you have to keep the spacer between the coupler and tb positioned just right to prevent any leaks. As for building your own, It's alot easier said then done. There's also a 1" and 1.5"(I think) steel tubes welded to the tb end. Easy, if you have access to a mig welder and have some welding skill. I'm not quite sure what it's for, but most likely a necessity. And you need to drill a hole for the sensor to fit in. For $80, my time is worth the extra cost.
~'98 F-150 XLT Reg. Cab Flareside 4x4, Black, 5.4L, 3.55LS, tow package, 285/75/r16 Mud Terrain BFG's,K&N,WMS Velocity Tube, GTS headlight covers, Alpine changer w/FM mod, Clifford alarm system w/keyless entry & starter disable // Future considerations: Bed mat, tonneau cover, 4" suspension lift or 3" body lift.
~'71 F-100 Sport Custom Reg.Cab
-390FE w/Edelbrock Performer RPM intake, 780cfm Holley, ported & polished cylinder heads,
Hydraulic Crane Cam, 10.5:1 CR, Black Jack headers, true double roller timing chain, and high volume oil pump
-C6 transmision w/B&M 2600rpm stall
-9" Ford Rearend w/4.10 Richmond Gears & 31 spline axles
-215/65/r15 Yokohama's for the front & 28"x13.5"x15" Mickey Thompson ET Street slicks for the back
Best 1/4 mile time @ 3500ft altitude 14.69secs @ 92mph
~2000 Suzuki RM125 Dirt Bike
-no need for any modifications! (yet)
~2001 Traxxas T-Maxx Nitro Monster Truck
Modifications: -180degree carb flip w/return spring installed
In addition to the hole and grommet for the sensor at the intake end, you would need fittings and hose at the throttle body end for the air breather hoses.
There are a few that have done what you're talking about, but I agree with fordification that the extra money is worth it. Plus you get the nice powdercoat finish.
2000 F150 XLT 4X4 Off Road 5.4L Reg. Cab 3.55
Performance Enhancemets:
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
All of the above, plus
Sony C7000X HU
Cerwin-Vega SS2502 components(Front)
Blaupunkt PCxp573s(Rear)
Radio-delay mod
Other Enhancements:
Extang Black Max Tonneau Cover
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
Sony C7000X HU
Radio-delay mod
Other Enhancements:
Yes it will accept the stock paper filter, and if you go with a K&N you need to get the OEM replacement filter.
As for the warranty concerns, no aftermarket add on can void your warranty unless it is proven that the part directly caused the failure.
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
Sony C7000X HU
Radio-delay mod
Other Enhancements:
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
Sony C7000X HU
Radio-delay mod
Other Enhancements:
I agree with F150Sven. Besides, you can always reinstall the stock air silencer tube and fender connection before you go to the dealer if you are really concerned.
Ian
99 Expedition EB
5.4l, 4x4, 4.10'S
WMS Tube, Bassani Cat Back Exhaust.
Superchip Flipchip on Order
Ian
99 Expedition EB
5.4l, 4x4, 4.10'S
