How hard to change Oil filter on 5.4??
Hey everyone, I've read that the remote filter is no longer available. I was wondering how hard the filter is to get to on the 5.4? I've never actually seen a 5.4 with the filter on the block. My experience with most Ford products has been that the filter is usually a pain to change. My Mark VII was a nightmare and the oil would run all over the power steering rack.
Thanks,
Steve
Hopefully future F-150 XLT Sport owner.
Current:
2001 Chevy Blazer LT-wife's
2000 Pontiac Grand Prix GTP- *Supercharged* My toy with a bunch of mods. Gp-owners.com member since Oct 99. Currently FOR SALE so I can get a truck!
Thanks,
Steve
Current:
You have to turn the wheel all the way to the right to access the oil filter on a 5.4.
'99 F150 SC, 4x2, Oxford white, flareside, 5.4,
bodyside mouldings, Snuglid hard tonneau, airbox and fresh air mods.
Duraliner drop-in (gave up on the Penda Nascar). Gibson Supertruck. Ford 2-piece bra. Catch-All floor mats. Image tail light covers. B-Quiet sound dampener in rear of cab. **** pile rug protecting spare tire (Raoul made me enter this)
No door cracks yet at 20K!!!
If you do like Marv1 said, it's a piece of cake on the 2WD. There is plenty of filter wrench access and 2 ways that look plausible; within the drip cup edge/the lower, or above the drip cup completely(choose this one).
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
How hard is it? Looks too hard for me (I burn toast and evaporate water...). My dealer does the Bubbabendover and gets my money.
...my first "big" truck
'99 Ford F-150 Lariat
4WD, 4DR - !!NO LONGER absolutely stock!!
* Superchips
* K&N FIPK GEN II
'99 Chrysler 300M
* Borla Cat-Bak
* K&N Filtercharger
www.atlantagamerz.com
www.f150online.com
www.300mclub.org
* Superchips
* K&N FIPK GEN II
'99 Chrysler 300M
* Borla Cat-Bak
* K&N Filtercharger
www.f150online.com
www.300mclub.org
Just did mine last night. Didn't need to turn the tires, didn't use a wrench (I put the last one on.) I just crawled under, undid the filter and let it drain. Btw I change it with Mobil 1 oil and Motorcraft filter ever 5-6K.
2000 f-150 red, XLT, 4x4, 5.4L, 3.55, sliding rear, 60/40, towing package??, keyless entry.
Airaid FIPK, ORP.
Airaid FIPK, ORP.
can someone post me instructions or how-to change your oil. i've never done it, so please don't laugh...
...ok, you can stop laughing now
TRUCK
2000 XLT 4.2 Auto
3.55 non-limited slip
Superchip
K&N filter in airbox mod
custom ported STOCK throttle body
PC
Thunderbird 1.1ghz @ 1.33ghz
Abit KT7A-Raid
384mb Kingmax PC-150 ram
60gig IBM gxp RAID array
Geforce2 GTS 64mb
TRUCK
2000 XLT 4.2 Auto
Superchip
PC
Abit KT7A-Raid
Geforce2 GTS 64mb
When you get your answer (which I'll read to learn), can you point me in the right direction of good "toast making and water boiling" instructions???
* Superchips
* K&N FIPK GEN II
'99 Chrysler 300M
* Borla Cat-Bak
* K&N Filtercharger
www.f150online.com
www.300mclub.org
* Superchips
* K&N FIPK GEN II
'99 Chrysler 300M
* Borla Cat-Bak
* K&N Filtercharger
www.f150online.com
www.300mclub.org
<font face="Verdana, Arial" size="2">Originally posted by Talleywacker:
</font>
</font>
1. Get a good floor jack and jackstands or a set of car ramps.
2. Warm up the vehicle so the oil gets circulated.
3. Remove drain plug and drain old oil into drain pan.
4. Reinstall drain plug
5. Remove Oil filter
6. Wipe some new oil on rubber seal on the new oil filter
7. Install new oil filter
8. Fill engine with fresh oil.
9. Make sure drain plug is tight (don't overtighten) and oil filter is tight (hand tighten or you'll regret it next time)
10. Check dipstick (car flat on ground)
11. Start engine and watch to make sure Oil gauge goes up.
12. Shut engine off and check for any leaks.
Those are the basics.
Steve
Current:
Just tried to change it today. I have a f-350 with the 5.4,4x4. Only have 1200 miles, but figured I would get rid of any factory grit,before going to a syntenic. Found 5w20 motorcraft, and a motorcraft filter. Drain plug no problem, the filter I could not get it off for the life of me. So I drained the oil, and then couldn't get the filter off. Bent it all up but no holes. So I put the fresh oil in and drove it to a quickee oil change place. The dirt bags would not try to get the oil filter off unless I paid for an oil change, so out went the new oil with 3 miles on it, and in went the "fresh oil" and my new filter. Damn 40 buck oil change all told. Have to get on of those gizmos that fit over the end, and you use a rachet.
I've been changing oil in my parent's vehicles since I was about 12 or 13 and I have always done it in my own vehicles. I try to avoid other people touching my cars if possible. Sometimes they cause more harm than good!
Steve
Current:
Steve
Current:
A 5.4 4x4 is a pain!!!!
I can't believe ford couldn't come up with something better than that!!
Stupid front pumpkin gets in the way!!!!!
I ended up buying one of those perfect fit filter wrenches that go on a 3/8 drive ratchet. Works fine for me! Still wish I had the remote filter behind the front bumper like the shop truck we have at work has.
MY TRUCK:
99 F-150 4x4, 5.4 Triton, 3.55 gears, Amazon Green-Harvest Gold two-tone.
MY MODIFICATIONS:
Lund bug shield
Window vent visors
17" Chrome ORP wheels
Clarion Pro-Audio in-dash CD
Connex 3300HP CB radio, K-40 antenna
Husky floor liners
Custom dual exhaust w/Flowmster muffler and dual 3" chrome tips
Hidden hitch
K&N Filter
SUPERCHIP FLIP CHIP...installed 2/27/01
Extang tonneu cover
Rancho RSX Shocks
MY TRUCK:
MY MODIFICATIONS:
Lund bug shield
Window vent visors
Husky floor liners
Hidden hitch
K&N Filter
Extang tonneu cover
Rancho RSX Shocks
Oil Filter is a 3 minute process with a fit over the end filter wrench, 12" of ratchet extension, and a swivel socket at the end.
Don't try to save 10$, get the wrench and swivel socket.
BEWARE:, make sure the old gasket comes off with the filter and does not stick to the block. I had a quick lube filter which I replaced with a Mobil 1 but the Mobil 1 seemed to tighten up strange. Took filter off and the o-ring gasket from the cheap piece of crap filter from Jiffy Lube was still on the block. Disaster waiting to happen.
2001 Screw, 4x4, 5.4L, 3.55LS, trailer tow III, 255-16 tires, skids, no cap yet.
Superchip
Gibson Stainless SS
AirRaid FIPK
Line X, other misc.
Superchip
Gibson Stainless SS
AirRaid FIPK
Line X, other misc.
<font face="Verdana, Arial" size="2">Originally posted by jimbos43:
<snip>Drain plug no problem, the filter I could not get it off for the life of me. So I drained the oil, and then couldn't get the filter off. Bent it all up but no holes. So I put the fresh oil in and drove it to a quickee oil change place. The dirt bags would not try to get the oil filter off unless I paid for an oil change, so out went the new oil with 3 miles on it, and in went the "fresh oil" and my new filter. Damn 40 buck oil change all told. Have to get on of those gizmos that fit over the end, and you use a rachet.</font>
One final thing. When you're working upside down and you're not used to doing it, there's a possibility that you might just be turning the filter/screw/etc. the wrong way. It's happened to me more times than I care to admit, even to myself!
The stock filter is the hardest to get off. Those "slip over the filter" wrenches will not work on a Motorcraft filter, and that is definitely the best way. Once you get the filter off the first time, use a filter that the slip on filter wrench will work with. I use a PurOne filter, but I'm sure other filters will work with it too.
Boss™
Ordered June 29th, 2000; took delivery Nov. 28th: 2001 F-150 Lariat, Oxford White/Silver Supercab 4x4, Styleside, 5.4L, 7700# payload, Class III Tow, 3.73LS, Skids, Leather Captains, 4W disc ABS, shift-on-fly, keyless.Engine build date: 10-25-00
Modifications:
"Protected by the Owner with his 2 friends, Smith & Wesson" sticker, Westin Chromed Stainless Nerf Bars, ARE LS II bed cover, Bedrug™, Gibson Swept Side Cat Back, K&N filter w/airbox mods, Hyper-White headlight & foglight bulbs, Pioneer DEH-8200R, Ventshades(not on back doors), Hood deflector, Superchip.
Future Modifications:
3" body lift with at least 33's, alarm/pager/auto start system, stereo system
Boss™
Modifications:
