COOLANT LEAK
Old Feb 15, 2001 | 10:18 PM
RYRROCKETMAN28's Avatar
Post COOLANT LEAK
I OWN 97 F150 XL 4.2 V6 5 SPEED TRANS 4X4
I GOT A COOLANT LEAK THAT COMES FROM THE FRONT PART OF THE BLOCK ON THE RIGHT SIDE .LET ME KNOW OF ANY IDEAS. THANKS BOB
Old Feb 15, 2001 | 10:22 PM
fordtec2001's Avatar
Post
try the timing cover or water pump bolts check to see if the gaskets are pushed out on the timing cover ?
ps get a pressure tester on the radiator system to find the leak ?
good luck
Old Feb 15, 2001 | 11:23 PM
Black98STX's Avatar
Post
RYRROCKETMAN28,
I'm pretty sure there is a recall on the 97 for a leak around the cover look at some of the post in the V6 section. Our go to your local Ford dealer and they can tell you if it is covered by the recall. Good Luck!
98 STX
4.2 V6 5SPD
3:55 Gears
Black Clearcoat
Mods(So Far)
Superchip
K&N Filter
Gibson Catback Side Swept(On Order!)
BugflectorII
Window Ventshades
Pendaliner
Pioneer 12 Disk Changer W/Wireless Remote
Things I Want
FIPK (Airaid,K&N)
Ignigtion Updrade(MSD,Jacobs)
Pulleys?
Old Feb 15, 2001 | 11:46 PM
BlownHarleyFord's Avatar
Post
Water pumps leak (read GUSH) like a bitch when they're on their last legs. If it's just little, probably not the pump it self.
Mike
Stay Out Of My Taildust
2000 Black Harley Davidson F-150
5.4 Liter v-8
K&N Air filter
20" Polished Aluminum Wheels
275/45/20 Goodyear GSII's
Billet Front Grille
Front Valence W/ driving lights and Billet Insert
3.55 Rear End
Leather Interior
Heated Seats
Hidden Hitch
Orange Pinstriping
Front and Rear Light Blackouts
Lowered 1" Front & Rear
Block heater
Old Mar 9, 2001 | 12:15 AM
mtrujillo's Avatar
Unhappy
Unfortunatlely my friend, you are a victim of the "front cover gasket recall". You need to go to your nearest ford dealer immediatly and get it replaced if it isn't too late already! If it is, then you will need a new engine, which could (in my case) take up to three weeks to repair! You need to let the dealer know that you know about this recall and you want the repair done. If the dealer is any kind of reputable dealer, they will supply you with a rental (mine did), also check and make sure that you did not receive a recall letter. If you are the second owner then obviously the dealer (if it was ford)either knew , or is trying to get out of using tech time (mechanic labor). Be extremely adamant when dealing with this or they will blow you off! Go to V-6 engines, there is a lady in there that I supplied the same advice to. GOOD LUCK!!!!!!
Old Mar 9, 2001 | 09:04 AM
GMB F-150's Avatar
Thumbs down
Hello I'm new to this board, but I had the same problem with my 97 F-150 leaking coolant. It was the timming cover gasket that was the problem which was fixed by Ford under warranty. So I would take it back to the dealer for a fix and the best of luck to you.
