To reset cp????
Old Mar 7, 2001 | 04:50 PM
00blk4BY's Avatar
Question To reset cp????
to reset the computer in my 2000,, do i need too take off both battery cables or just the negitive????
Old Mar 8, 2001 | 09:21 AM
Flatlander's Avatar
Smile
Just remove the negative and turn your headlight switch on for about 5 minutes. This will drain all the energy completely.
'97 F-150 Lariat SuperCab 4X4
  • White/Silver, 4.6L, Auto.,Open 3:55
  • Tinted Windows/Bedmat/Toolbox/Lund Bug Deflector/Ventvisors/Extra Horns
  • 265/75/16 BFGoodrich AT's on polished 16x8 AR-136's
  • Cat-back Dual Exhaust (Straight pipes with big chrome tips)
  • Black Polar Bear Grille Guard
  • Monkey'd around with the Torsion Bars
Old Mar 8, 2001 | 09:39 AM
max mitchell's Avatar
Cool
Make sure that you turn off your headlights before you reconnect the battery !!
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
Old Mar 8, 2001 | 06:50 PM
JMC's Avatar
JMC
25 Year Member
Post
Flatlander,
Please explain why you have to turn on the headlights for 5 minutes.
Kindest regards
Jean Marc Chartier
Old Mar 8, 2001 | 06:55 PM
Flatlander's Avatar
Smile
'Cause that's what the smart people on here say, I'm not very good with all the electrical, current, amperage, terms and stuff, so I don't really know why.
Old Mar 8, 2001 | 11:18 PM
redlariet's Avatar
Post
There are small electrical components in any computerized device called capacitors. These act as a tiny battery & store electric charge briefly. To discharge these, there has to be a discharge load, such as lights. Probably the hood light would be enough but headlights make sure as modern chips will run on near 0 volts.
97 Lariet-sc-4.6-4x off road-auto-3.55 LS-
superchip-Airraid-Perma-cool electric fan & controller
