to reset or not to reset
Old May 5, 2002 | 05:15 PM
tnboy11580's Avatar
Unhappy to reset or not to reset
should i reset my computer after an exaust swap and after i install my airaid intake? if so is it like old school trucks and you just disconect the battery for like 20 seconds?
Old May 5, 2002 | 05:42 PM
max mitchell's Avatar
tnboy11580-
If you didn't do a battery disconnect for your intake installation, you can do it afterwards to speed up the learning process. Disconnect negative battery terminal, turn on headlights for a minute, TURN HEADLIGHTS OFF, reconnect battery. You'll notice a gauge sweep when you turn on the ignition.
Old May 5, 2002 | 06:13 PM
tnboy11580's Avatar
Talking thank you
so i did need to do a battery disconnect huh? i appreciate you telling me how to do it. we'll see if it helps!
Old May 5, 2002 | 06:34 PM
tnboy11580-
You're Welcome !! The battery is normally disconnected working with the sensors during the intake install.
Old May 6, 2002 | 06:09 PM
Chicago_guy's Avatar
reset yes
yup reset it makes the computor re learn what is new set differnt idle and rpms and stuff youll notice a differnce, just after you do the disconnect and connect, let it warm up then drive, not hard at first takes a few good cold starts to notice it but reseting is the thing to do after any mods
