Unhappy with Performance!
I have a 97 F150 2WD Flareside 4.6L truck. The truck has a 3in catback exhaust with a flowmaster 50 series, Superchip, and K&N FIPK unit. She also has a 3.5 inch suspension lift and 33 inch tires on her. I am unhappy with her performance. I feel as if she is a dog! I want to make the B!@#$ch haul **** while still maintaining a somewhat acceptable freeway app. What can I do?
Silver
1997 F150 4.6L, Flare side,American Racing Baja 16X8's, Goodyear Wrangler's LT305/70/16's ATS, Flowmaster 50 series, 3" cat,3.5 Suspension Lift kit, Tinted Windows, Superchip, Rancho 5000's
Silver
Gears gears gears-----------410 or 430
2000 F-150, XLT, SC, 5.4, 4X4, 355 LS, ORP, Black/Silver, class III, single CD, sliding glass, med. gray, keyless, elect. shift, engine date 8-18-99, Superchip. '93 Harley Fatboy Black & tons of chrome
Tires may be hurting you a little. For each inch above what was stock on your truck you lessen your effective gear ratio by approx .15 - .3 (depends on who you talk to, I think it is closer to the .15)
ex - stock tires w/3.55 gears would effectively approx be 3.40 - 3.25 with tires 1 inch taller.
Not sure what the stock tire height is, but you probably know, so you can do the math.
Since Silverback asked the question, what should a person expect to pay for a gear change from 3:55 to 4:10 (professionally done)? Has ayone been through this? And really, how much more at the bottom end is one going to see? Obviously there will be a reduction of gas mileage. Does anyone have some stats after their change?
2000 Flareside SCab 4x4, 5.4 w/3:55, Oxford w/gray leather captain's, upgraded Lariat pkg, Class III towing pkg, all power, monogramed dash cover, fog+high beam mod, expy console, billet third brake light cover, K&N, custom exhaust (single in-dual out) with Flowmaster 40, Superchipped. Hellwig bar is next.
Vacherie Boys has the same truck as I do. the only difference is it's older so his 5.4L has 25 less HP and 15 less torque.
He has a better 1/4 mile time than me because he lowered it a couple of inches.
I didn't lift but, his lowering has the same effect.
You lift, you lose.
You lift, you lose.
I don't mean to bash the previos post, but I see alot of people that have that misconception. Losing the fan in favor of an electric my give you 3-5 HP, but know where near 15. I have tried this route as well as many other mustang guys over at the Corral.net and the dyno numbers aren't that supportive of some of the claims. One other drawback is that most of the electric fans don't pull enough CFM and/or cover enough of the A/C drier to make the A/C as effective in traffic at idle, as the stock fan.
2001 F-140 SuperCrew 4X4 Lariot
5.4, 3.55 LS, Wimpy stock 17" tires
-MB Quart Reference, 2 JL-8W0
silverback,
I would go with the gears. I went from 30.6 inch OEM to 33 inch BFG MTs. My truck is a dog now. The equivalent ratio is now 3.25. With this tire size I would need 3.88s to get me back to the OEM 3.55. I would like 4.10 gears with the OEM tires so I would need 4.56 gears to give me an equivalent 4.17 gear. Figure about $500.00 per differential.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
OK cajunfiref150, I'll make a note of it but, I liked 'vacherie boys' better. It sounded like a racing team and I could take solace in the fact I was outnumbered.
1999 Ford F150 Lariat RegCab shortbed 5.4L 3.55LS Towpkg Line-X
15.714@85.21
15.714@85.21
Silverback,
I just change my 3.55 for 4.10. Cost just ove $600 but included bearing and seal changes. Worth every dime.
WarEagle
98 F150 Lariat extended cab, Pacific Green/Silver Frost,
Grey Leather Capt chairs, AM/FM/Cass/6-cd changer,
full tint, color matched bug deflector, vent shades,
A.R.E. hard bed cover, Ultra type 50 polished wheels,
BF Goodrich 315 55R x 16 Sport Truck Radial T/As, 4.6L,
AT, Towing Package, Airaid, Superchip, JBA headers,Flowmaster dual
exhaust, Flowmaster 50 series muffler, 4.10 gears
WarEagle
