Headers?? Are they worth it for that PRICE?! (CHIP?????)
um..... how the h*ll do you put 5.4 heads on a 4.6, I am extremely perplexed. Well thats what my old truck has in it the trusty 4.6( Ive gotta keep that truck I got it when I was a soph in h-school weve had good times together and I will not let her go). I always thought that my 4.6 was shorter and that the only thing that would bolt on was the muffler, hey do you guys have any info on porting the T-body on a 4.6
a little help would help thumper still does get driven everyday.
Fightin' Texas Aggie
1997 f150 sc
4.6l V8
no muffler hidden pipes
265x75x16
Mts
2x10inch kicker competions
need more power help me guys!!!!!!!!!
1997 f150 sc
4.6l V8
265x75x16
Mts
HI!... YES! 5.4L "PI" heads will bolt directly onto a 4.6L engine. You have to run the 5.4L "PI" cams though to get the full potential and H.P of these heads. You must still use the 4.6L's camshaft timing chains as the 5.4L's are longer because of the deck height is taller on the 5.4L. If you do a 5.4L head swap on a 4.6L, you will most likely have to get a SUPERCHIP or have your existing SUPERCHIP reprogramed for the conversion. I would advise you call MIKE TROYER on the reprogram specifics. If you decide to go the 5.4 "PI" head route then spend the extra money and get SEAN HYLAND to do a STAGE 3 port and polish job on them. The STAGE 3 head work is worth another 55H.P over what the stock "PI" head will give you. You can easily gain 80H.P by doing both of these things. Hope this helps some of you guys out.
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
FYI,
The Power Improved Heads are the heads from a 99+ Ford Mustang 4.6 SOHC engine. They will bolt onto a truck 4.6 engine. I am looking into which Valve cover thay use. On the 4.6 Trucks the Engines for the 1997-98 model year used either the Windsor or Romeo engine. For 99 poduction of all triton 4.6 was supposed to switch to Romeo. The Mustang uses a Romeo engine so there may be problems with the valve cover. The Windsor Valve cover has 13 bolts and the Romeo has 11. So count your bolts.
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
BFG 285/75 R16 MTs,
Borla Cat Back, Headman Headers,
Modified Air Cleaner Outlet Tube
and air box, Ported Throttle body,
Shortened MAF sensor tower,
K&N air filter,
Superchips
Regards
Jean Marc Chartier
BFG 285/75 R16 MTs,
K&N air filter,
Superchips
WOW! 80hp from new heads? im impressed, definately cheaper than a supercharger, and it produces almost as much, i think i will have to go this route (though i will eventually get the supercharger as well, but later) Way i figure, between the exhaust, heads, port/polish, superchip, and fipk, i should be gaining about 100hp at the fly wheel! im impressed!
so whats the goin rate for the heads and the port/polish, and havin 70000 km on my truck, would it be a good idea to port/polish more of the engine?
THANX
The TRUCK:
1999 Black F150 XLT Sport 4x4 Flareside, 4.6 Triton V-8, Manual Transmission, Captains Chairs, Power Everything.
Appearance Changes:
Button-down Tonneau Cover, Webasto Sunroof, Spray-on Bed-liner, Xenon Fog and Headlights, Blackwidow Car Alarm, Window Tint, Wet Okole Seats (ALL).
Stereo:
2 10" Kicker CompVR's on Fosgate 360a2, Kicker Components Front & Fosgate 5x7 Rear on Fosgate 200a4, Blaupunkt Muchen Deck.
Performance:
265/70 R17 Yokohama Geolandar A/T+, Borla Split-Rear Cat-Back Exhaust, K&N FIPK.
THANX
The TRUCK:
Appearance Changes:
Stereo:
Performance:
HI!... COOLSVILLE : You might be surprised on how much it will cost you to get that extra 80H.P. SEAN HYLAND MOTORSPORTS wants $2500.00(U.S) to do a STAGE 3 port and polish job. A set of new "PI" 5.4 heads will run you about $1000.00(U.S) and then you have to buy the cams, about $650.00(U.S). Then you have to pay someone to remove your old heads and install your new ones, BIG MONEY! Then there's all yhe gaskets and new head bolts required to do the swap. It would only be worth while if you are going to do a "GROUND UP" rebuild on another 5.4 or 4.6 donour engine, like I am.
Okay, guys. I'm not sure that I am clear on the header application for a 4.6, if you install the 5.4 P.I. heads?
Since I have already installed headers for my 4.6, would they fit the 5.4 heads?
Is there any real advantage to polishing the heads for street use?
'00 F150 SC w/ 4.6L, Oxford white, Gray Int., leather steering wheel, Lariat/4x4 fender lip molding (painted Oxford White), GTS slotted tailight covers (painted Oxford White), Lariat front grille/headlight assembly and front bumper cap (painted Oxford White), lower factory bumper w/ driving lights, Ford billit hitch cover, Line-X-bed, carbon fiber hood/ bug deflector.
Performance: 75mm BBK throttle body, Poweraid spacer, Granatelli 80mm MAS, K&N Generation II intake system, ASP pulleys, 2-16" Hayden Rapid Cool electric fans, Gibson headers, Gibson cat back exhaust (split rear) 3:73 rear gears, custom (flip chip) Superchip.
Future mods.: white face guages, 2/4 drop kit, Lightening 18x9.5 wheels, 295/18 Z rated Goodyears, fiberglass toneau cover, Stillen front bumper cover, MSD or Jacobs electronic ignition upgrade, Magnacharger
HI!... BLACK F-150 OFFROAD : The pre-"99" intake manifold ports are smaller but can be corrected with a gasket port job. The ports are the same shape but just slightly smaller. They can be opened up to match the "99" "PI" heads. As for the manifold runner control or "IMRC" my "99" "PI" 5.4 has it. That's IF you are talking about the ABS plastic lower plenim that has the row of "BUTTERFLYS" controlling air flow through the upper plenim to the heads.
