Is It Ok To Wash Under My Hood With a Hose
Old Jan 22, 2001 | 01:45 AM
Bullsback's Avatar
Post Is It Ok To Wash Under My Hood With a Hose
Hi, I just went offroading and my underhood is a complete mess, and I am going to be putting my FIPK on pretty soon, within the next 2 weeks, and I want to be installing it with a clean engine. Will it ruin anything if I just spray the inside down with a hose?
Old Jan 22, 2001 | 01:51 AM
moose-man's Avatar
Question
Thats a good question!
Something i would like to know myself.
I would assume if you coverd all the electrical components with plastic or such and make sure everything is seald it would be fine. Only thing i also wonder is, if you do this should you do it while the engine is cold? I ask this becuase if the engine is hot cold water on it could warp or something more extreme.
97 F150 4.6 v8 longbed
_ _ _ _ _______ _ _ _ _
K&N Air filter
K&N FIPK TECH MOD & REMOVED ELBOW SILENCER
_ _ _ _ ______ _ _ _ _
Hyper White xenon bulbs
Bedliner and Raven Shell
_ _ _ _ ________ _ _ _ _
6 disc cd changer
OIL & FILTER USED Mobil 1
_ _ _ _ _________ _ _ _ _
Gas used TEXACO & CHEVRON
Old Jan 22, 2001 | 05:37 AM
LARIAT1's Avatar
From: INDIANA,.....USA " Where more than Corn grows in Indiana"!!!
Exclamation
Be real careful!!!!!! Only try this if the engine has cooled down to be able to touch it with your hand. Than try only to wash areas with as little water as you can.
Lariat#1
1997 Red/Silver F150 Lariat Flareside 3 Dr. SC..... ORP & Tow Package, Complete Lariat Option Package ,{APPEARANCE} GTS Projector Beam /Carbon Fiber Headlite Covers,AVS Tail Lite Slots & Door Sill Protectors,Flareside tail lites wired to work upper&lower lenses together,Owens Fg. Step Boards, Tinted Windows,Ford 2-Piece Bra,Lighted Ford Logo in Grill,20" Chrome Exhaust Tips,A.R.E Bed Cover Lid,Pendaliner Inner Tail Gate Protector,Zie-Bart Total Paint & Under Coating W/ Sounder Deadener Protection, Lariat #1 Plate under glass on Front Bumper,Custom made Ford Red Window Decals,Blue Tinted Rear Lic. Plate Protector,Blue Billet Valve Stem Caps, Ford Lited Hitch Receiver Cover that works off brakes lites, HD Bed Mat, Red reflectors above Rear Bumper {PERFORMANCE} 4.6L WINDSOR Auto, 3.55LS, 4-Wheel ABS,Platinum 3 Spark Plugs,K&N Air Filter W/ modified stock MAF side air box,Outerwears Blue Pre-Filter Cover,Tornado Air Man.,Perma-Cool Oil Filter Relocation Kit,Motorcraft Racing Oil Filter FL-1HP,Dual Exhaust System W/Stock Muffler,NAPA Ceramix Carbon Ceramic Premuim Brake Pads(Front),Goodyear Wrangler A/TS Tires,55 Watt Halogen(replacement) Reverse Lites, Pilot 55 watt Halogen (add-on) Reverse Lites on Hitch under truck,Driving Lamps upgraded to 55 Watt Cool Blue Halogen Bulbs,Pilot Bright Whites headlite bulb replacements 65/55 watts,Driving Lamps(Foglites) work W/ High Beams On & Driving Lamps(Foglites) also work (ON or OFF) W/ Park Lamps On W/Switched Relay, A.R.E Cover wired W/interior(dome) light wired to a mounted door jam switch thats wired to hood light,SurgeGuard by Calterm {AUDIO} Stock In-Dash Cass. W/6 Disc Changer & 2 Stock Speakers(back) & 2 Pioneer TS-A6865 3- Ways(front),Black felted inner front door speaker openings , all speakers dynomat lined,Trenz Billet #3 Antenna {SECURITY} Ford Total Security System W/ Motion Alarm All on factory Key Fob,Ford Warning Decals on Windows,A.R.E Cover & Hood also wired to Alarm System, Hitch Pin locking system This is LARIAT#1..... IN The Great State Of Indiana "Where more than corn grows in Indiana".........http://hometown.aol.com/terrylariat1...page/auto.html A Very Proud Member of ...www.f150online.com
Soon to have Flareside Rear Step Bumper re-plated (Triple Chrome Plated)
Old Jan 22, 2001 | 09:01 AM
Marv1's Avatar
Post
I wash mine at the car wash all the time with NO problems...I use the high pressure spray setting too. If its metal I get real close with the wand but I try to avoid hitting electrical stuff like the alternator.
'99 F150 SC, 4x2, Oxford white, flareside, 5.4,
bodyside mouldings, Snuglid hard tonneau, airbox and fresh air mods.
Duraliner drop-in (gave up on the Penda Nascar). Gibson Supertruck. Ford 2-piece bra. Catch-All floor mats. Image tail light covers. B-Quiet sound dampener in rear of cab. **** pile rug protecting spare tire (Raoul made me enter this)
No door cracks yet at 13K!!!
Old Jan 22, 2001 | 10:18 AM
p_ferlow's Avatar
Post
I haven't had any probs washing my motor, but use car wash soap in water on the hoses, air cleaner, battery, etc and hose it down with a gentle spray. I wouldn't use a pressure washer, especially around the plugs or distributor caps. Do it at home with a cold motor. But start it right away afterwards. With my old Ranger, if you didn't start it afterwards, the water would seep into ignition components and would damn hard to start. I always found it best to start it right away, let it warm up to steam off all the moisture. Used to use GUNK engine cleaner. Haven't yet with the F150 cause the block isn't greasy and none of th engine seals are leaking.
Old Jan 22, 2001 | 10:54 AM
XTRUKY's Avatar
Post
I go to the quarter car washes all the time, I have never had a problem, on any of my cars.
I do hot soap, then rinse, no problemo
Old Jan 22, 2001 | 11:09 AM
Zeus 2k1's Avatar
From: Overland Park, Kansas (Kansas City) - Soon to be Ft. Worth, TX
Post
According to the Lightning FAQ page, you are NEVER supposed to use a high pressure spray on your engine. Also, make sure the engine is cold, for steam can get to places that you don't want it, and it will cause problems. Read on:
http://www.webtechnik.com/lightning/default.htm
Old Jan 22, 2001 | 11:49 AM
Neal's Avatar
Cool
HI!... I power wash my engine compartment about once a week with a high power washer. My local power washer also has engine degreaser that comes out of the wand. All I do is remove my external K&N filter and cover the pipe with a plastic bag and elastic band. Then I simply power wash it. I've done this when the engine is cold and hot and never had a problem after 2 years. Just one warning though, try not to direct the power washer spray directly into the alternator or you can wash the grease from the bearings. This will cause the alternator to squeek eventually.
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old Jan 22, 2001 | 07:59 PM
hobbit's Avatar
Post
I spray everything wil full strength simple green let it soak a few minutes and just rinse with the hose with a gentle spray. Works Great and have never had any problems. I do avoid the altenator and try to avoid as many electrical connectors as possible.
Hobbit
99 XLT,4.6L Auto,4X4,tow pkge,Factory Side Steps and Mudflaps, K&N filter,BugflectorII, Amazon Green/Silver, Pace Edwards Rolltop Cover.
Old Jan 22, 2001 | 08:33 PM
Dennis's Avatar
Lightbulb
My '97 and '99 Owner's Manuals had information about washing our engines. I'd assume later models also have this information in their manuals. There are places you should cover with plastic (I use plastic grocery bags) to keep dry.
There's a lot of information in the various manuals.
Old Jan 23, 2001 | 12:37 AM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Talking
I use high pressure every time,never had a single problem. I just wrap the K&N filter with plastic groc. bags. Use Gunk,or equal quality stuff. spray liberally with tire
dressing after it's dry and wipe off the excess. Looks SO good!!,,,98
p.s. do it before your fuel rails rust
98 F-150 4.6 Litre XLT2wd Ext. cab
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Stillen Quad light air dam, sweet!!
Euro taillights
Cobra 75WXST cb w/weather alert
[b]Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good
Viper alarm
On the way/wheels,tires, etc..etc.......
the monochromatic boogie is done,cool!.
Come see my new pictures@ www.my-f150.com
officialtomwaits.com
reverendhortonheat.com
WOW,what a cool site!
FENDER GUITARS ROCK!!!
Had to take the picture out,it was way too out of date,,,,98
Old Jan 23, 2001 | 09:17 AM
2001's Avatar
Post
Best engine cleaner out there right now is a product called "Simple Green"
it works like no other cleaner out there, it is not a chemical based product but a organic based which is nice on all plastic's, rubber and paints....but it eats away at grease and dirt!
Buy a bottle and make yourself happy!
Old Jan 23, 2001 | 10:17 AM
JMTruck's Avatar
Post
My engine cleaning method looks very similar to 98SCREAMER. No problems up to date.
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications:
Split Fire Spark Plugs
K&N FIPK
Gibson Supertruck Exhaust System
Stepshield door sill protectors
Performance Accesories 3" Body Lift
Superlift 3" lift blocks
Performance Lift Lips
Gabriel Gas Ryder LT VST Shocks
Daystar Front Anti-sway Bar Polyurethane Bushings
Heckethorn Steering Stabilizer
35x12.5R16.5LT BFG All Terrain KO's
16.5x9.75 American Eagle 589's.
Photos at: http://www.communicomgroup.com/jmtruck
Old Jan 23, 2001 | 11:07 AM
DonW's Avatar
Post
I wash the motor every time I was the truck, I use simple green in spry bottel. No high pressure wash though. never a hot moter..
Old Jan 23, 2001 | 07:50 PM
Waldo0506's Avatar
Banned
From: Collierville,TN,Confederate States of America |><|
Post
First I put a coat of simple green on the engine, then i put armoral tire shine over that, then i wash it off with the water hose about 1/4 on. it looks like new, when people see it they ask me if its a 99 model
Waldo
'97 XLT Clearcoat Red 4x2
17 inch Wheels,Stepside, K&N,bedliner, 32 inch tires, flowmasters, deep tint, big Ford oval on back window, 5 spd, platinum plugs, CB, hidden hitch, ford emblem hitch cover and a little wal-mart smiley face on the antenna wearing a coboy hat :-)
http://www.my-f150.com/waldo0506
