82 mm mass air flow sensor..need input
i got a billet aluminum 82mm mass air flow sensor custom made to work with my airaid fipk. i am using the stock sensor except it is now housed in 82mm diameter pipe. I reset the computer and noticed immediately that the throttle is more responsive. My question is, i am thinking of removing the housing around the element of the sensor itself. would this benefit me or is it a no no? please help.
oops, my sig did not show up. i have a 2000 Expedition 4.6, airaid fipk, throttle body spacer, ultraflow muffler.
2000 Expedition 4.6 3.31 Rear
AIRAID Fipk with Poweraid Spacer
UltraFlow muffler
82 mm Mass Air Flow Sensor
UltraFlow muffler
somebody tried this a while back. He took a dremel tool and removes the tower inside the mass air flow meter. He ended up having all kinds of problems. This is a old mustang trick, it works sometimes, but sometimes it causes major problems.
1999 F150 4x4 4.6V8 regcab/shortbed
Oxford White with Wedgewood Blue two tone, with Blue Captains chairs
Bullet Cat Back, Superchip, K&N FIPK Intake.
Centerline Saber rims 17x8" with Firestone GTA 275/60hr-17 tires.
Alpine CDA-7845, ADS P640 Amp, Focal Poly Kevlar seperates.
SILVER 2001 LIGHTNING on order
http://members.tripod.com/donf150/Welcome/id7.html
That would be me. Do not remove the tower it is a sampling tube that measures the air coming in. With out it my truck ran like Sh!!.
Mods:
Smitty Built:Brush guard,Nerf Bars
Jacobs Ignition
Fabtech leveling kit
Pro comp extra travel shocks fr+ba
Micky Thompson Mtx 185/75r16
hypertech super chip
Rancho 2" blocks+add a leaf
Moble 1 synthetic 0w30 oil
Red line atf and rear end lube
performance accessories 3" body lift+gap guards
Pioneer p2000 and kenwood 100x4 amp, planet audio 5x6 fr 6x9 in rear
Machanical water and oil guages+tach
bed liner, Swiss Cap
80/100w superblue headlamps
4.10 rear end gears
Hellwig rear antisway bar
Mods:
Jacobs Ignition
4.10 rear end gears
A word of caution on opening up the intake too much. It will lean out your fuel/air ratio. I went from a stock MAF to a Pro M, which needed to be calibrated for 19 LB injectors. My mixture changed from 10.5 to 11.5 to 1. Which is perfect, but I would have it checked before you put the pedal to the metal.
Road_rage 1, was that you that epoxied the tower back on? Are you still running that MAF or did you get another one?
