FRAM "SureDrain" (again)
Hey all,
I seen this at Walmart about 2 weeks ago, I got home and e-mailed the company and I finally recieved this reply, hope it helps!! BTW, I believe it was about $13 which I thought was a decent price!!!
Joey "O"
Mr. O'Connell:
> Thank you for the e-mail regarding a Fram SureDrain oil drain plug for
your 2002 F150 4.6L engine. We welcome the
> opportunity to be of service.
> Many of the 2002-2001 Ford SureDrain oil drain plug applications are not
listed due to pending vehicle research.
> However, we recently purchased the 2002 Ford F150 4.6L engine original
equipment oil drain plug for evaluation. We have
> identified this drain plug as having 14mm x 1.5mm thread. The SD2 is the
Fram SureDrain oil drain plug that corresponds
> to this thread size.
> Thank you for choosing Fram products.
> Cordially,
> Scott Jacobs
> Catalog/Technical Service Representative
> Catalog/Technical Service Department
Joey "O"
Mr. O'Connell:
> Cordially,
> Scott Jacobs
What is the "Sure Drain" Oil plug?
I have replaced all the drain plugs on my vehicals for yaers with the FOMOTO Valve (kind of small locking ball valve that replaces the drain plug and lets me drain oil without removing plug or making a mess) Is the "Sure Drain" plug similar to this?
Petrol
Petrol
It is kinds the same thing. It is a piece you put in place of your oil drain plug, it has a threaded end on it with a protective cap. The other piece is a threaded hose connection and as you thraed it onto the piece in the truck, it opens the drain valve and goes through the hose into your container.
check it out at. www.fram.com
Joey "O"
Joey "O"
