Buying a new engine!!?????!!!!????!!
O.K. Looks like I am buying a new engine to replace the 4.6L with 135,000 miles on it. Afraid to put new heads on and blow out the bottom. Where can I get a good engine? I don't really want a piston slapp'n rebuild from Ford. Oh, this is to replace a '97. And can I put a 5.4L in it's place? Is it a better engine. Any input would be appreciated.
'97 F150 4.6L 4x2 Lariat extended cab sb Flareside green/tan
Here is the latest on the saga of the engine. To bring you up to speed the engine has been experiencing coolant in the #8 sparkplug cavity. After 3 trips to the local dealer and nowhere closer to a solution we went to an outside repair shop. With the help of this site and the many helpful and informed people here(especially "pkrwuds" and "birdman") we were able to encourage the shop to do a thorough examination of the engine before replacing the engine or even the heads. What it all comes down to we think is leaking intake manifold gaskets and possibly bad intake manifold.
dmailman
I don't think I would change the engine if it is OK other than the intake or gaskets. I believe I read the whole engine goes for 3 to 4K$.
97 Lariet-sc-4.6-4x off road-auto-3.55 LS-
superchip-K&N-3"
pvc air box mod-Granetelli MAF
superchip-K&N-3"
redlariet - Your definalty right, it would be much cheaper to replace the intake and gaskets, but what if that isn't the problem?
dmailman - u should look into just changing the intake and gaskets, if that is the problem it would be more economical and just plain easier. In these new cars it's alot more then bolting up a new engine to the tranny, if your replace the 4.6 w/ a 5.4 you need to find a 5.4 computer to go with it. Not sure if all 4.6's share the same computer though.
Don`t know how reliable a source this is but there is one on EBAY that I saw tonight going for 1,000 so far. I believe it had 33,000 miles on it. I don`t know if I would buy a engine this way but it was there.
http://cgi.ebay.com/ebaymotors/aw-cg...488565&r=0&t=0
I think the gasket and intakes would be the first step I would take before engine swap.
2000 F150 SC, XLT, Bright Red/Silver 4x2,Auto, 5.4, 3.55LS,CD, sliding rear window, Tow package,Captains chairs,Remote Entry, Ford Bedliner, molded splash guards,Stainless step bars and bed rails.
FM40 single in/Single out the side.Clear Corners just installed.Pretty much stock now but waiting for performance mods to include FIPK,,Superchip, new wheels/tires and new audio.
