Synthetic advantages?
Old Jan 15, 2001 | 06:50 PM
ballistic's Avatar
Post Synthetic advantages?
I am very interested in changing to Synthetic, either Amsoil or Mobil 1. My 98 F150 4.6l has 47k, I know that this will result in greater protection for my engine but will the change improve mileage and performance along with greater ?
Bottom line I will problably replace all fluids with synthetic products...but I have a concern about leaks.....everything is clean so far. I guess I'm looking for some reassurance that I will not be creating problems now vs. preventing problems down the road. Thanks in advance the the help.
F-150 extended cab, 4.6L, K&N Gen II, Gibson Cat-back single 3" exhaust, Jacobs ignition and wires, Super Chip.
Old Jan 15, 2001 | 08:19 PM
msparks's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by ballistic:
</font>
Rest assured synthetics don't cause leaks! If you truck is in proper working order and doens't have any current leaks you will not have any after switching!
Lube-Direct
New Lubrication Forums
Old Jan 16, 2001 | 10:13 AM
Matt90GT's Avatar
Post
If you have no leaks now, then you are fine.
For milage, after switching the engine, tranny and transfer case over to synthetic, I got a 1mpg increase.
That is not bad at all. But the best part is that I am using the amsoil products and will not have to change the oil for a long time!
Forgot to add, I switched over at 68K. Bought the truck with 65K. You can feel a difference in power!
[This message has been edited by Matt90GT (edited 01-16-2001).]
Old Jan 16, 2001 | 10:57 AM
doorslammer69's Avatar
Post
I switched to Amsoil Series 2000 at 3,000 miles. I change oil & filter "Amsoil SDF11" every 10,000 miles. I now have 109,000+ miles on my 97 f150 4.6. No leaks & it doesn't burn a drop. Amsoil's sleeper product is PI, give it a try...Mark.
PS: Oooooops Series 2000 0W30...
Old Jan 16, 2001 | 11:09 AM
msparks's Avatar
Post
I second the PI! I used to have to run midgrade or I would get pinging. Now I use PI and regular, no pinging. And I save money since I only have to use about 2 oz of PI per tank!
Lube-Direct
