'98 4.6L died
Old Mar 19, 2002 | 05:05 AM
utu582's Avatar
'98 4.6L died
Driving at 45 mph. Motor died for 2 seconds, came back to life for 10 seconds. Died for good. Coasted to a stop. Motor turns over but will not start. Any suggestions on this "High-Tech" stuff, BEFORE I take it to the shop? Thanks, Gregory
Old Mar 19, 2002 | 04:07 PM
f-150_91's Avatar
try checking the fuel pump pressure , it might have gone south. I'm no technician I"m just tryin to help out
Old Mar 19, 2002 | 06:14 PM
CoolHandLuke's Avatar
Might want to check your fuel pump cut-off inertia switch behind the passenger side kick panel. Did it die after you hit a pothole or something?
Old Mar 20, 2002 | 06:14 PM
hmustang's Avatar
Sounds like it might be the fuel pump has gone bad.
Old Mar 21, 2002 | 01:22 PM
utu582's Avatar
The local Ford dealer says there is a short in the fuse box, that goes to the main computer. They had a tough time finding it, so it'll only cost me $300 for labor, and $100 for a new fuse box. Thanks for all the replies
Old Mar 21, 2002 | 01:39 PM
mxracer514's Avatar
What caused the short? I have repaired several shorted fuse boxes and gem modules that were damaged du toa waterleak in the left cowl, windshield area. You might want to run a hose over that area and make sure there is no waterleak. When there is a leak water runs right onto the fuse box and gem module.
Old Mar 21, 2002 | 01:48 PM
utu582's Avatar
MXRacer....
Thanks for the tip. I will pass that info onto the dealer. Most likely it just broke, not shorted out by water, etc. The thing sets in my garage almost 98% of the time, as it's my second vehicle, and I cringe at the gas mileage. Gregory
