Tap at start
Old Sep 19, 2003 | 12:10 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Exclamation
Mine rattles on the first startup, if the oil level is below the halfway point on the stick. As long as I keep it full, no noise. Cold seems to make it worse, if the oil is down. Using a Bosch filter now, a Mobil-1 before. The problem was the same on both filters.,,,,98
Old Sep 19, 2003 | 12:54 PM
LE PEW's Avatar
The 4.6 does have lifters/hydraulic lash adjusters, they are in a different location is all.
Back in the day ............. you would check the PVC valve by removing it from the engine when it is not running and shaking it. It was supposed to rattle, meaning it's not gummed up and stuck. It works kinda like a check valve that runs off engine vacume.
My 4.6 also makes various noises at start up but not always. I fixed the noises by installing a remote starter. Now I stay in the house while it warms up and I dont hear a thing!
Good luck.
Old Sep 19, 2003 | 01:20 PM
PacNWBlueOval's Avatar
My old 99 5.4L did the same thing. I live in a neighborhood on a slope and I have to drive uphill to get out of it in the mornings. The 99 used to make a slight tapping sound at idle and would get louder when under moderate load traveling uphill in the morning. I used 5W-30 Mobil 1 and a PureONE oil filter so I'm confident I got quick upper end lubrication.
Not sure the long-term effects because I traded it in after a couple of years.
